Simulator Discussions
invalid file system when trying to mount a volume on the simulator to my Mac
ToddErickson
Hello,
I am new to NetApp and the Simulator. I am running the simulator in Fusion on my Mac.  I worked through the Simulate ONTAP 9.7 Installation and Setup Guide.  When I try to mount a volume on the simulator onto my Mac using
mount -t nfs 192.168.1.102:/volume1 /mnt/netapp
I get:
mount: /mnt/netapp: invalid file system.
showmount -e 192.168.1.102 returns:
Exports list on 192.168.1.102:
/                                   Everyone
/volume1                            Everyone
Any guidance or help would be appreciated.
3 REPLIES 3
darr613
Hello Tod,
I believe the -a parameter refers to the filesystem extension
most Linux use ext, ext2, ext3, ext4
You could try mounting it in the fstab file
Create the /svm1 directory to serve as a mounting point for the NFS volume you will be mounting.
[root@rhel1 ~]# mkdir /svm1
Add an entry for the NFS mount to the fstab file.
[root@rhel1 ~]# echo "svm1:/ /svm1 nfs rw,defaults 0 0" >> /etc/fstab
Verify the fstab file contains the new entry you just created.
[root@rhel1 ~]# grep svm1 /etc/fstab
Mount all the file systems listed in the fstab file.
[root@rhel1 ~]# mount -a
View a list of the mounted file systems.
[root@rhel1 ~]# df
Navigate into the /svm1 directory.
[root@rhel1 ~]# cd /svm1
Notice that you should see the volume that you previously junctioned into the SVM's namespace.
[root@rhel1 svm1]# ls /svm1
SeanHatfield
did you create the /mnt/netapp directory first?
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
wareer
1.Ensure the NFS Service is Enabled:
Confirm that NFS is enabled on the NetApp simulator. You can check this using the ONTAP CLI:
vserver nfs show
2.Verify that the NFS server on UNIX is up:
systemctl status nfs-utils
3.Check Firewall/Network Issues:
Make sure that there are no firewall rules or network issues blocking NFS traffic between your Mac and the simulator.
4.Review NetApp's export policy:
vserver export-policy rule show
5.NFS Version Compatibility:
Check if there are any compatibility issues with the NFS version being used. Sometimes specifying the version might help:
mount -t nfs -o vers=3 192.168.1.102:/volume1 /mnt/netapp
