Software Development Kit (SDK) and API Discussions
HOSTS authentication problem
shalondwood
I'm trying to use host-based authentication (h
osts.equiv), but it's failing. I get the error:
"User  does not have capability to invoke API quota-report."
If it's not clear, there are two spaces after 'User', as if it were printing a null username. Sure enough, from the log:
Tue Oct 27 11:44:14 CDT [near19: useradmin.unauthorized.user:warning]: User '' denied access - missing required capability: 'api-quota-report'
Am I missing something?
24 REPLIES 24
kcollins
This most certainly IS a vulnerability!  ANY USER can claim to be root and run commands. That user clearly is NOT root, so it should not be authenticated!
The real user id should be passed through the SDK for this "fallback" authentication method and only allowed if the real user is allowed via hosts.equiv.
Thanks,
Kevin
kvishal
A non root user cannot execute API with user input as root. The API will error out, if the user is not a root.
Something like this
Vishal Kulkarni
Member Technical Staff
SMAI
NetApp
080-41844244 Direct
9986500905 Mobile
[email protected]
www.netapp.com
kcollins
A non root user *IS* running this and there is no error. I am using it right now as my own user with no issues:
cpafisc8-> id
uid=14665(cokm) gid=508(techteam) groups=506(tape),507(usradm),513(taxdart),666(security)
cpafisc8-> cat hello_ontapi.pl
#!/usr/bin/perl
my $VERSION = '1.0';    # Controls the SDK release.
use strict;
use lib '/util/bin/netapp/manage-ontap-sdk-3.5.1/lib/perl/NetApp';
use NaServer;
use Pod::Usage;
die pod2usage(
        verbose => 1
) unless $ARGV[0];
our $filer = $ARGV[0];
our $s = NaServer->new($filer, 1, 1);
$s->set_style("LOGIN");
$s->set_admin_user("root", "");
our $output = $s->invoke( "system-get-version" );
if ($output->results_errno != 0) {
        our $r = $output->results_reason();
        print "Failed: $r\n";
else {
        our $r = $output->child_get_string( "version" );
        print "$r\n";
cpafisc8-> ./hello_ontapi.pl cpafisnas2
NetApp Release 7.2.5.1: Wed Jun 25 08:55:16 PDT 2008
Thanks,
Kevin
craig_cowen
I realize this might be old news to some but, testing on a SIM version 8.0.1, setting the options httpd.admin.hostsequiv.enable to on solved this for me.
