Software Development Kit (SDK) and API Discussions
How to print some aggr info in text format using API
PBRam
I am trying to print the aggregate info (size and used space) in text format . Can some one help.
Ontap: 8.3.2 p2
api = NaElement("aggr-space-get-iter")
xi = NaElement("desired-attributes")
api.child_add(xi)
xi1 = NaElement("space-information")
xi.child_add(xi1)
xi1.child_add_string("aggregate","<aggregate>")
xi1.child_add_string("aggregate-size","<aggregate-size>")
xi1.child_add_string("physical-used","<physical-used>")
xi1.child_add_string("physical-used-percent","<physical-used-percent>")
xi2 = NaElement("query")
api.child_add(xi2)
xi3 = NaElement("space-information")
xi2.child_add(xi3)
xi3.child_add_string("aggregate","aggr1*")
xo = s.invoke_elem(api)
if (xo.results_status() == "failed") :
print ("Error:\n")
print (xo.sprintf())
sys.exit (1)
aggrs= xo.child_get("attributes-list").child_get("space-information").children_get()
for aggr in aggrs:
print (aggrs.child_get("aggregate"))
Getting following error,
AttributeError: 'list' object has no attribute 'child_get'
4 REPLIES 4
francoisbnc
You have to iterate through attributes-list
aggrs= xo.child_get("attributes-list").children_get()
for aggr in aggrs:
print ('name {} {}'.format(aggr.child_get_string("aggregate"),aggr.child_get_string("physical-used")))
 hope that help
PBRam
Worked!! Thank you very much 🙂
Srinu_mar
i m getting the similar issue.tried the below suggestion.still no luck. Cna some one help me?
Traceback (most recent call last):
  File "5_aggrstatuinfo.py", line 29, in <module>
    aggr_list = out.child_get("attributes-list").children_get()
AttributeError: 'NoneType' object has no attribute 'children_get'
 my code is:
from NaServer import *
obj = NaServer(“IPaddress”,1,150)
obj.set_server_type("FILER")
obj.set_transport_type("HTTPS")
obj.set_port("443")
obj.set_style("LOGIN")
obj.set_admin_user("admin”,”XXXXXXXX”)
#xo = NaElement("desired-attributes")
#api.child_add(xo)
xi = NaElement("query")
api.child_add(xi)
xo1 = NaElement("space-information")
xi.child_add(xo1)
xo1.child_add_string("aggregate","<aggregate-Name>")
xo1.child_add_string("aggregate-size","<aggregate-size>")
xo1.child_add_string("physical-used","<physical-used>")
xo1.child_add_string("physical-used-percentage","<physical-used-percentage>")
out= obj.invoke_elem(api)
aggr_list = out.child_get("aggregates")
if (out.results_status == "failed"):
print("error\n")
print(out.sprintf())
sys.exit()
for aggrs in aggr_list.children_get():
print("a\n")
francoisbnc
desired-attributes and query are two different things
Here an example where you need aggregate space information without query (filter).
api = NaElement("aggr-get-iter")
api.child_add(xi)
xo1 = NaElement("aggr-attributes")
xi.child_add(xo1)
xo2 = NaElement("aggr-space-attributes");
xo2.child_add_string("size-total", "<size-total>")
xo1.child_add(xo2);
print(xi.sprintf())
out = obj.invoke_elem(api)
    print("error\n")
aggrslist = out.child_get("attributes-list")
aggrs = aggrslist.children_get()
for aggr in aggrs:
    aggrname = aggr.child_get_string("aggregate-name")
    aggrspaceattr = aggr.child_get("aggr-space-attributes")
    aggrspace = aggrspaceattr.child_get_string("size-total")
    print(f'{aggrname}  {aggrspace}')
 I just added size-total information, you can add more.
Considere to use to have the full overview.
ZExplore Development Interface
Version : 2.3.1
NetApp Manageability SDK release 9.7P1
Hope that helps.
