Software Development Kit (SDK) and API Discussions
Interworking problem between 7-mode api and Cdot volume
HeehyeonLee
Hello
I have a question about the Snaplock API.
Currently, we are using API services by linking 7-Mode snaplock volumes with xtorm.
Are C-dot Snaplock volumes compatible with the existing 7-Mode API?
If compatibility is possible, provide the settings required for compatibility.
If it's not compatible, where can I get a file like the one pictured below?
thanks
1 REPLY 1
pedro_rocha
I don't know if this can help you: https://library.netapp.com/ecmdocs/ECMLP2874708/html/index.html
