Software Development Kit (SDK) and API Discussions
Issues with ansible netapp module na_ontap_volume to create volume on Ontap
HimanshuRajpal
Hi Netapp Support Team,
I have been trying to use ansible netapp module na_ontap_volume to create volume on Ontap. Tried to scenarios, both failing with different error messages.
Could you please help me with this, don’t what’s going wrong here?
Scenario 1:
[ansible@server ~]$ cat ansible_vol.yaml
hostname: 'x.x.x.x'
username: 'xxxxxx'
password: 'xxxxxxxx'
vserver: 'xxxx_xxx_xxx'
aggr: 'xxxx_xxxxx_xxxx'
vol_name: 'ansibleVol'
[ansible@server ~]$ cat volume_lifecycle.yaml
- hosts: localhost
  collections:
    - netapp.ontap
  name: Volume Lifecycle
  vars_files:
    /home/ansible/ansible_vol.yaml
  tasks:
  - name: Volume Create
    na_ontap_volume:
      state: present
      name: “{{ vol_name }}”
      vserver: “{{ vserver }}”
      aggregate_name: “{{ aggr }}”
      size_unit: gb
      policy: default
      junction_path: “/{{ vol_name }}”
      hostname: “{{ hostname }}”
      username: “{{ username }}”
      password: “{{ password }}”
      https: True
      validate_certs: false
[ansible@server ~]$ ansible-playbook volume_lifecycle.yaml --extra-vars "@ansible_vol.yaml"
[WARNING]: No inventory was parsed, only implicit localhost is available
[WARNING]: provided hosts list is empty, only localhost is available. Note that the implicit localhost does not match 'all'
PLAY [Volume Lifecycle] ***************************************************************************************************************************************************************************************
TASK [Gathering Facts] ****************************************************************************************************************************************************************************************
ok: [localhost]
TASK [Volume Create] ******************************************************************************************************************************************************************************************
An exception occurred during task execution. To see the full traceback, use -vvv. The error was: netapp_lib.api.zapi.zapi.NaApiError: NetApp API failed. Reason - Unexpected error:UnicodeEncodeError('latin-1', '“x.x.x.x”:443', 0, 1, 'ordinal not in range(256)')
fatal: [localhost]: FAILED! => {"changed": false, "msg": "Error fetching volume “ansibleVol” : NetApp API failed. Reason - Unexpected error:UnicodeEncodeError('latin-1', '“x.x.x.x”:443', 0, 1, 'ordinal not in range(256)')"}
PLAY RECAP ****************************************************************************************************************************************************************************************************
localhost                  : ok=1    changed=0    unreachable=0    failed=1    skipped=0    rescued=0    ignored=0
[ansible@server ~]$
Scenario 2:
hostname: ‘x.x.x.x’
username: 'xxxxxxx'
password: 'xxxxx@xxx@'
vserver: 'xxxxx_xxx_xxx'
aggr: 'xxxx_xxxx_xxxx'
- hosts: localhost
  collections:
    - netapp.ontap
  vars_files:
  tasks:
    na_ontap_volume:
      state: present
      size: “{{ size }}”
      size_unit: gb
      policy: default
      https: True
ok: [localhost]
fatal: [localhost]: FAILED! => {"changed": false, "msg": "argument size is of type <class 'str'> and we were unable to convert to int: <class 'str'> cannot be converted to an int"}
[ansible@server ~]$
Regards
Himanshu Rajpal
1 ACCEPTED SOLUTION
JohnChampion
You'll get help faster through the Slack channel - go to netapp.io and click on the "Slack" icon (top-right) to get the invite.  Ansible is supported through Slack - on the #configurationmgmt channel.
Try adding "  | int" to the end of your size: setting perhaps?
size: “{{ size | int }}”
3 REPLIES 3
JohnChampion
HimanshuRajpal
Thanks for your response. I will move this communication to Slack channel
However, I already tried size: “{{ size | int}}” but no luck. See below.
- hosts: localhost
collections:
- netapp.ontap
vars_files:
tasks:
na_ontap_volume:
state: present
size_unit: gb
policy: default
https: True
hostname: 'x.x.x.x'
username: 'xxxxxxx'
password: 'xxxxxx@xxx'
vserver: 'xxxxxxxx'
aggr: 'xxx_xxx_xxxx'
[ansible@server ~]$
ok: [localhost]
[ansible@server ~]$
MarktheSpark
Hello,
Just in case anyone else stumbles over this problem again, I'll post the solution here.
The issue lies with the quotation mark characters that present in the exmple code at https://netapp.io/2018/10/11/getting-started-with-netapp-and-ansible-first-playbook-example/.
When you copy and paste this into your editor, VSCode for me, those quotation mark characters are copied as unicode characters U+201C and U+201D. Assible doesn't seem to like these so produces the error you reported above.
The solution is to replace these with normal quotation marks, unicode U+0022.
Hope that helps anyone else that is falling at the first hurdle on their NetApp with Ansible journey!.
