Software Development Kit (SDK) and API Discussions
Using 5.1 NM SDK with Certificate based authentication against cluster mode 8.2
amarumoto
Hello all, I am attempting to use the 5.1 NM SDK via Perl to automate some processes against a cluster mode 8.2 vServer. Based on the SDK documentation for the "NaServer::set_style" method my options for authentication against the filer are LOGIN, HOSTS, or CERTIFICATE. Since this is cluster mode and there is no longer a /etc/hosts.equiv file that means all I can use are LOGIN and CERTIFICATE. If I choose LOGIN I can access all of the functions of the API and everything works perfectly, however I don't really want to have to embed a username and password inside of a script.
I followed the article below to get CERTIFICATE authentication setup. I can tell that the CERTIFICATE authentication is working because I can use the API 'system-get-version' object to retrieve the version and other attributes from the vServer. However if I attempt to use any of the volume related APIs such as 'volume-get-iter' or 'volume-clone-get' I receive a failed results status from the NaServer::invoke_elem method with a reason of 'not authorized for that command'. It appears that there may only be a limited set of API functionality when using CERTIFICATE authentication over LOGIN.
Has anyone had success using CERTIFICATE authetication against an 8.2 cluster mode vServer? any insight would be appreciated! thanks!
https://communities.netapp.com/community/interfaces_and_tools/developer/blog/2013/07/30/using-sdk-with-certificate-based-authentication-cba
1 ACCEPTED SOLUTION
aashray
Hi,
You can access all APIs and have no limit on access if you use CBA as the "admin" user.
Basically while creating the certificate give the common-name as : admin
Then using "security login create" command create a user with username "admin" , application as "ontapi" and authmethod as "cert".
This should make it work.
I have also updated the article at : https://communities.netapp.com/community/interfaces_and_tools/developer/blog/2013/07/30/using-sdk-with-certificate-based-authentication-cba
Thanks for pointing this out.
Hope I helped.
Please let me know.
Best Regards
Aashray Arora
12 REPLIES 12
aashray
Hi,
Hope I helped.
Please let me know.
Best Regards
Aashray Arora
amarumoto
Thank you very much for the reply, this pointed me in the right direction.......I had originally created my certificate/vServer login with a common name unique to our environment. Then I recreated the certificate/vServer login with a common name of 'admin' but I still had the same error message as before. So I recreated the certificate/vServer login again with a common name of 'vsadmin' an then everything was working correctly, I had full API functionality,
Thanks Again!
Drew
aashray
Great. Anytime. Thanks for your response, it will help me document CBA usage better.
richard5
If I create a new user ("limteduser") with specific RBAC access, e.g. snap list but not delete, can I generate a self-signed certificate with the common name as "limiteduser"?
Granting cluster-wide roles is not popular with customers.
amarumoto
I think you should be able to use a custom role that contains whatever access you like but in my experience it is the name of the user and the common name in the certificate (both should be the same) that were critical. Like you I initially created a user account name that made sense to me, like 'automation' and then created a certificate with common name of 'automation'. The CBA seemed work but with very limited functionality. It wasn't until I used the username of 'vsadmin' that I had complete success. My 'vsadmin' user is assigned the 'vsadmin' role, but I just tested changing the role the 'vsadmin-readonly' and the CBA still works but obviously with read only permissions. So I would try using either 'admin' or 'vsdamin' as your username and certificate common name and assign the user your custom role and I think you should be good.......good luck!
SMRUTIMANDAL
Hi,
The link above is not working. Can you please provide a fresh link.
Thanks.
pmbidara
Hi ,
Pasting the contents from the link here....
Greetings,
There have been a lot of questions on how Certificate Based Authentication (CBA) can be used with NMSDK to connect to the filer. CBA for NMSDK is supported if you are on Clustered Data ONTAP 8.2. This means your scripts need not have the username/password to call the APIs on the filer.
Here I will show you how you can use a self signed client certificate to login to your filer.
Steps :
  • Create a self-signed certificate using openssl commands. When asked for common name, please use "admin". Else you may not get access to many APIs.
               Example :
  1. openssl req -x509 -nodes -days 365 -newkey rsa:1024 -keyout yourKeyFileName.key -out yourCertName.pem
               It will look something like this : ( cat yourCertName.pem)
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
  • Install the certificate in your filer (running Clustered Data ONTAP 8.2 )
command :
  1. security certificate install -type client-ca -vserver yourAdminVserver
You will get a prompt saying : Please enter Certificate: Press <Enter> when done
Paste the certificate created in the above step (including the Begin and End lines) and press enter.
  • Two important things :
    • Check if client authentication is enabled inthe cluster.
> security ssl show -vserver yourAdminVserver
Vserver: yourAdminVserver
   Server Certificate Issuing CA: yourAdminVserver.cert
   Server Certificate Serial Number: 50C8AB18
   Server Certificate Common Name: yourAdminVserver.cert
SSL Server Authentication Enabled: true
SSL Client Authentication Enabled: true
                              If it is disabled then enable using this option :
                                         security ssl modify –vserver yourAdminVserver -client-enabled true
  • You should create a securitylogin with the client name that you have mentioned in the certificate.
  1. security login create -username admin -application ontapi -authmethod cert -role admin -vserver yourAdminVserver
  • Now you are ready to call APIs by providing the certificate and key file.
Example 1 : Run the python apitest using CBA - this file can be found in your NMSDK5.1 bundle in the folder :  netapp-manageability-sdk-5.2/src/sample/Data_ONTAP/Python
  1. python apitest.py -C ~/yourCertName.pem -K ~/yourKeyFileName.key <IP.XXX.XXX.XXX> system-get-version
                      Example 2 : Run the apitest.exe found in netapp-manageability-sdk-5.2\bin\nt
  1. exe -C cert.pem -K keyFile.key <IP.XXX.XXX.XXX> volume-get-iterHope it worked well. Feel free to ask me any questions you might have.
SMRUTIMANDAL
Thanks. The issue is resolved.
yannb
It seems like if I try to use a different user, it doesn't work. I get a "Not authorized for that command (13003)" error.
Now, if I assign a password to that user, it works, even if I keep authenticating with a certificate, without putting that password anywhere in my script.
Is that expecetd?
yannb
By the way, this is working find with 8.3.2
The problems show with 8.2.1
yannb
See BUG 801316 (Fixed in 8.2.2)
arminwiesel_fts
Thanks, this helped me very much.
Still I had to dig out the parameters I needed in my own script out of the apitest.pl and got it working like this with my simulator:
my $Cluster = new NaServer('192.168.0.22',1,7);
$Cluster->set_transport_type('HTTPS');
$Cluster->set_style('CERTIFICATE');
$Cluster->set_client_cert_and_key('/cf.d/yourCertName.pem','/cf.d/yourKeyFileName.key');
$Cluster->set_server_cert_verification(0);
$Cluster->set_server_type('FILER');
$Cluster->set_port(443);
