Software Development Kit (SDK) and API Discussions
python + SDK vserver info gives a error.
RaghavaCheruku
cat vserver_info1.py
#!/usr/bin/env python3
import sys
sys.path.append("/opt/netapp-manageability-sdk-9.4/lib/python/NetApp")
from NaServer import *
from getpass import getpass
def vserver_info(s):
    t1 = NaElement("vserver-get-iter")
    out = s.invoke_elem(t1)
    if (out.results_status() == "failed"):
        print("Error:\n")
        print(out.sprintf())
        sys.exit(1)
    #print(out.sprintf())
    info = dict()
    info = out.child_get("attributes-list")
    for info1 in info.children_get():
        print("vserver-Name: %s" % info1.child_get_string("vserver-name"))
        print("vserver-type: %s" % info1.child_get_string("vserver-type"))
        print("vserver state %s" % info1.child_get_string("state"))
        print("vserver-ipspace: %s" % info1.child_get_string("ipspace"))
        print("vserver root volume%s" % info1.child_get_string("root-volume"))
        print("vserver language: %s" % info1.child_get_string("language"))
        print("Vserver snapshot policy: %s" % info1.child_get_string("snapshot-policy"))
        pro = dict()
        pro = info1.child_get("allowed-protocols")
        for pro1 in pro.children_get():
            print("protocol enabled: %s" % pro1.child_get_string("protocol"))
def main():
    s = NaServer(filer, 1, 3)
    resp = s.set_style('LOGIN')
    if (resp and resp.results_errno() != 0):
        r = resp.results_reason()
        print("Failed to set authentication style " + r + "\n")
        sys.exit(2)
    s.set_admin_user(user, pw)
    resp = s.set_transport_type('HTTPS')
        print("Unable to set HTTP transport " + r + "\n")
        sys.exit(2)
    vserver_info(s)
#args = len(sys.argv) - 1
#if (args < 2):
#    print_usage()
#filer = sys.argv[1]
#user = sys.argv[2]
#pw = getpass("please end the password :")
filer = 'netapp-bb98.labx.mo.sap.corp'
user = 'admin'
pw = 'netapp123'
main()
when I execute the program,
#python3 vserver_info1.py
vserver-Name: Cluster
vserver-type: system
vserver state None
vserver-ipspace: Cluster
vserver root volumeNone
vserver language: None
Vserver snapshot policy: none
Traceback (most recent call last):
  File "vserver_info1.py", line 65, in <module>
    main()
  File "vserver_info1.py", line 50, in main
    vserver_info(s)
  File "vserver_info1.py", line 29, in vserver_info
AttributeError: 'NoneType' object has no attribute 'children_get'
can someone help me to understand whats wrong here.  how to fix the issue.
regards
Raghava.
0 REPLIES 0
