VMware Solutions Discussions
IMT: VMware Compatibility Guide
JS_Patil
Following link provides VMware's compatibility with Ontap device(IMT)
https://www.vmware.com/resources/compatibility/search.php
It returns IMT data on click of button:"Update and view result", I want to fetch the same data using python script, so need APIs for the same.
Please help.
2 REPLIES 2
AlexDawson
Hi there!
This is probably a better question for vmware - I found this link which suggests they had one in the past - but I can't seem to find any more information on it.
Hope this helps!
JS_Patil
Yes, you are correct, Thanks!
I just want to fetch that data using python script.
