VMware Solutions Discussions
Load balancing does not work with NIC Teaming on ESX 4.0 update 2
amitgupta12
Environment :
ESX 4.0 udpate 2
FAS 3140
Nortel Switches
We have teamed 4 NIC as part of a vSwitch on the ESX and configured for "IP Hash" as the Load balancing policy
On the Nortel side these 4 ports have been aggregated together using LACP.
NetApp is also using LACP
During testing, we have found that traffic from the VMware host to the Nortel switch is only using 1 of the 4 configured ports. If we turn that interface off, all the traffic flows through another interface ( but only 1 interface is used).. What should be done to enable Load Balancing between the NICs that have been teamed together.. Any suggestions ?
Thanks
Amit
1 ACCEPTED SOLUTION
forgette
Let's say you have 192.168.0.201 configured as the ip for svifa.  It might look something like this:
ifconfig svifa 192.168.0.201 netmask 255.255.255.0 up
You can then add some additional ip addresses like this:
ifconfig svifa alias 192.168.0.202
ifconfig svifa alias 192.168.0.203
ifconfig svifa alias 192.168.0.204
When VSC provisions a new datastores, it will mount them like this:
192.168.0.201:/vol/newDatastoreA
192.168.0.202:/vol/newDatastoreB
192.168.0.203:/vol/newDatastoreC
192.168.0.204:/vol/newDatastoreD
If you start a VM on newDatastoreA and one on newDatastoreB, you should see ESX using 2 different ethernet interfaces.
9 REPLIES 9
forgette
Hi Amit,
Please take a look at TR 3749 NetApp and VMware vSphere Storage Best Practices. It deals with the exact issue you are experiencing.
Cheers,
-Eric
amitgupta12
Thanks Eric.. I did use the recommendations outlined in TR 3749 when designing the environment but appears that something is still missing.
The traffic should be going over multiple NICs ( that are teamed together in the vswitch ) but that is not happening. Only one NIC is being used.
Thanks
forgette
In order for ESX to take advantage of the “Route based on IP hash” in the Load-balancing policy, you'll need multiple IP address (aliases) on the VIF on the controller.  If you want traffic over all 4 ports, you'll need 4 datastores each mounted using a different ip address (alias on the vif).  If you use RCU or the provisioning plug-in in VSC 2.0 this balancing happens automatically for you (as long as the aliases are on the vif).
Thanks Again Eric..
The way I have got my Storage Controllers configured is :
(output from /etc/rc )
vif create single vifa e0a e0b
vif create lacp vifb -b ip e4a e4c
vif create lacp vifc -b ip e4b e4d
vif create single svifa vifb vifc
The IP is configured for the svifa and I do not have any aliases configured.
I am however using VSC 2.0 for provisioning...
Thanks
forgette
Did configure an alias for the svifa. Mounted a datastore from this new IP... Still the traffic is going over just one NIC on the Vmware side....
Amit
peterl
Your rc file says svifa is single-mode.  That's part of the problem - only one NIC will be active at a time on the NetApp side.  That, and your general problem leads me to the next thing:
Are your switches and the ports on the ESX and filer side configured for some stacking technology that allows link aggregation using active ports on both switches?  I believe Nortel calls this SMLT or DMLT depending on the switch family/model.
Peter
amitgupta12
The svif is made up of vibc and vifb each of which have 2 active interfaces...
But anyhow Eric's solution worked. We just had to remount the NFS datastores using the alias IP
Thanks
Amit
deannamcneil
I did have a question for Eric: Does the load balancing address assignments get lopsided over time or does it seem to work out? I am worried that the math "starts over" every time I open an instance of vSphere and will get too many address assignments on one single address. Thanks!
