VMware Solutions Discussions
Problem with installing SMVI vSphere Plugin
simonhaeni
Hello
I've got a problem with installing the SMVI vSphere Plugin (Windows Server 2008 R2, vSphere vCenter 4.1).
In the last steps of the installation i get the following error message:
The NetApp vSphere Plugin Framework hast not yet been started. Try to load localhost:8143/Register.html in your browser.
If it does not display, then there is a problem with the installation.
The application is installed after that, but no Plugin in the vCenter...
Can anybody help me?
greetings,
simon
4 REPLIES 4
udo_braunschweiger
Hello Simon
we had a s issue today, we could not install VSC 2.1 on Vcenter Server Windows 2008 R2 64 bit, the error message was exactly the same.
Our server is NOT MEMBER of a Active Directory Domain.
-There was no User Account Control Active
-We werde connected to the Console Session via RDP
"Run as Administrator" on the VSC-2.1-win64.exe did not work to Install the VSC successfully
After a few trials we:
Installed Java RuntimeEnviroment for 32bit Windows
and changed the Credentials for the NetApp VSphere Plugin Service from LocalSystem to the BULITIN\Administrator Account.
Then it worked fine for us.
regards Udo
jacques_guensherian
Hello,
Looking for an answer about this problem. You solved it! thanks to you.
udo_braunschweiger
Hello
Thank you for the feedback!
Mit freundlichen Grüßen / Kind Regards
Udo Braunschweiger
Sent from my mobile device, pleaase excuse typos and shortys
AVONGREECEIT
Hi
My case (on w2k8 64 bit ) was solved after changing service login to buildin\administrator
no need to install Java
thank you all
