VMware Solutions Discussions
Question regarding LACP with VLAN creates
JGPSHNTAP
Ok, so I need some clarification.
I'm currently running 8.1.2p2 and I'm wondering where i'm going wrong
My rc file looks like
# Network setup for 10 Gbit connection
ifgrp create lacp vif10g-a -b ip e1a e1b
vlan create vif10g-a 2508
ifconfig e1a flowcontrol send
ifconfig e1b flowcontrol send
ifconfig vif10g-a-2508 10.10.255.100 netmask 255.255.255.0 mtusize 9000 partner vif10g-b-2508
ifconfig vif10g-a-2508 nfo
route add default 10.10.255.1
routed on
When I fail the cluster over to the partner node, we get this message
hostname*> Replaying takeover WAFL log
ifgrp: vif10g-a is not mapped to a local ifgrp
add net default: gateway 10.10.255.1
And then I got to partner mode and type ifgrp status
"No configured ifgrps present"
But if I do ifconfig -a
i see the interface come up  (see below)
vif10g-a-2508: flags=0x2bee863<UP,BROADCAST,RUNNING,MULTICAST,MULTIHOST,PARTNER_UP,TCPCKSUM> mtu 9000
        takeover mode (vif10g-b-2508)
        ether 02:a0:98:31:dd:62 (Enabled interface group)
hostnamea/hostnameb> vif status
ifgrp: command "vif" is deprecated in favor of command "ifgrp"
vif10a-g-2508 and I can ping it
Is this normal behavior?
Shouldn't we see the vif come up?
7 REPLIES 7
dcornely1
Can you provide the rc file from the partner node as well?  This way we can see what the network config is there to help with troubleshooting.
Also, I suggest you place your flowcontrol commands before your ifgrp create command (and if you're using VMware NFS datastores off this array then flowcontrol should be none) as it operates on the underlying interfaces not the ifgrp itself so you might as well set that first.  At least that's what I have in my environment and had no issues.
This may also help:
https://forums.netapp.com/thread/14286
JGPSHNTAP
Ok, the partner rc looks like
ifgrp create lacp vif10g-b -b ip e1a e1b
vlan create vif10g-b 2508
ifconfig vif10g-b-2508 10.10.255.101 netmask 255.255.255.0 mtusize 9000 partner vif10g-a-2508
ifconfig vif10g-b-2508 nfo
routed on
Yeah, i've been meaning to take off flow control
AGUMADAVALLI
Hi there,
I have provided the sample of how a rc and hosts files look below:
The best practice is to specify all the ips in the hosts files then the rc file.
RC file:
hostname __________
#Remove the flowcontrol send 2 lines
ifconfig vif10g-a-2508 `hostname`-vif10g-a-2508 netmask 255.255.255.0 mtusize 9000 partner  vif10g-b-2508
#No need of NFO line too
routed on
HOSTS file:
<IP>    <hostname>-vif10g-a-2508
Moreover, while you are trying for takeover specify the option -n which clear the wafl log errors.
Thank you
AK G
JGPSHNTAP
Couple of questions..
Why is this best practice -  `hostname`-vif10g-a-2508?
Also, why did you pull out NFO?
AGUMADAVALLI
NFO is not needed from 8.X as it is automatically enabled via the
options cf.takeover.on_network_interface_failure on
options cf.takeover.on_network_interface_failure.policy all_nics
thank you,
AK G
JGPSHNTAP
AK G -
Ok, i'm still a little confused here.. In partner mode when the cluster is failed over, should you not see any ifgrps?
aborzenkov
You still need to mark interface that has to trigger failover with "ifconfig ... nfo"
