VMware Solutions Discussions
There are no matching storage systems found for the selected SCP
RoboSmasher32
Hello everyone,
I have 2 identical NetApps AFF-C250.
On one NetApp I was able to successfully use the ontap vmware plugin to add the datastores.
On the other one I cannot and get this error:
I've compared both my netapps but not having any luck finding anything different.
Anyone have some pointers?
Thanks!
1 ACCEPTED SOLUTION
PravinKumar
Hi,
You shall try the below options:
  • On step 1 General of the wizard, check the option "do not use an SCP"
  • Select an SCP that matches the FAS or AFF system from the dropdown
  • Create a custom SCP that matches the storage type (FAS or AFF) and additional features like encryption.
KB article: https://kb.netapp.com/data-mgmt/OTV/VSC_Kbs/VSC_OTV_there_are_no_storage_system_that_match_with_the_selected_SCP
Thanks and Regards,
Pravin Kumar
3 REPLIES 3
cedric_renauld
Hello,
Your two C250 are managed by the plugin ?
In the system section
And waht are your licence on the 2 C250
RoboSmasher32
1 plugin per C250.
OnTap One would be the license.
PravinKumar
Hi,
Thanks and Regards,
Pravin Kumar
