VMware Solutions Discussions
VSC 6. Resizing NFS datastore ISSUES Storage not found
peter65
Greets all,
using vsc 6 When trying to resize a NFS datstore on a cdot system running 8.3P2. I get the following message:
"The selected datastore does not reside on any of the netapp storage controllers configured in Virtual Storage Console. This operation cannot be completed."
I assure you the storage has been added.  Any hints tips or ideas..?
3 REPLIES 3
georgevj
Plese see if this helps.
https://library.netapp.com/ecmdocs/ECMP1120486/html/GUID-8B127AFC-B4EE-415E-9B62-67A59190AC9C.html
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Cannot find the answer you need? No need to open a support case - just CHAT and we’ll handle it for you.
peter65
Thanks for the note. However this did not work. Additionally while it is trying to "resize" the "cancel" buttons are greyed out and not clickable for an action.
Mladen
Hi,
Has same issue in my lab environment. If you check kamino.log (C:\Program Files\NetApp\Virtual Storage Console\log) you should be able to find line similar to this (search for "not yet been fully discoverred" string)
Controller: 8fbef3a5-b2e8-11e5-84dc-0050569634b4(addr=192.168.2.70:443, user=admin) has not yet been fully discovered by Kamino.
The reason why it's not fully discovered is (from the same kamino.log file)
TRACE [RawHttpZAPIInvoker] - Calling zapi on 192.168.2.70:443, secure=true, useTLS=true
DEBUG [ZAPIInvoker] - retryIfApplicable: message=netapp.manage.NaAPIFailedException: Server chose TLSv1, but that protocol version is not enabled or not supported by the client. (errno=51) nae=netapp.manage.NaAPIFailedException: Server chose TLSv1, but that protocol version is not enabled or not supported by the client. (errno=51)
And indeed, I changed TLS versions as described here: https://kb.netapp.com/support/index?page=content&id=2026327&locale=en_US
1. Open %Programfiles%\Netapp\Virtual Storage Console\wrapper\wrapper.conf
     Locate the wrapper.java.additional.X lines (should be 7)
2. Add the following additional line:
  wrapper.java.additional.8=-Dhttps.protocols=TLSv1,TLSv1.1,TLSv1.2
3. Restart VSC service
Hope this helps.
Regards,
Mladen
