VMware Solutions Discussions
Volume reallocation measure in Ontap 9.3
KH1979
I am running the Volume Reallocation Measure in Ontap 9.3 and the just finishes successfully but there is no output on the hotspot value either in the EMS event log.  When I perform a volume reallocation show after job completes there is no info.
Where can I find the output from this command when completed?
1 REPLY 1
Sergey_Osipov
https://docs.netapp.com/ontap-9/topic/com.netapp.doc.dot-cm-cmpr-930/volume__reallocation__measure.html?cp=4_4_27_28_0
 At the end of each check, the system logs the optimization results in the Event Message System (EMS). If you use the logfile, the system records detailed information about the LUN, file, or volume layout in the log file. To view previous measure-only reallocation checks, use the volume reallocation show command.
