Virtualization Environments
Qtrees not populating in NetApp Shift Toolkit resource group creation workflow
RobbyLCC22
I am attempting to test migrations from VMware to Proxmox via the NetApp Shift Toolkit. I have added the source and destination platforms into the toolkit, provisioned Qtrees on the associated volumes, and discovery completes without issue. When I attempt to create a Resource Group, following the selection of datastore and target VMs, the Qtree selection dropdown appears empty and displays "No Options."
Curiously, when I add KVM as a destination platform and walk back to the same Qtree selection, it is populated and shows the available entries as expected. Has anyone else experienced this issue with Proxmox as the destination platform specifically?
The environments are as follows:
VMware vSphere 8.0.3j
ONTAP MetroCluster 9.16.1P9 (NFSv3)
Proxmox 9.2.2
2 REPLIES 2
ChanceBingen
@NiMo
@RobbyLCC22 are you running the latest Shift Toolkit? It should be 8.0P1 or later.
@ChanceBingenYes, the installed version is 8.0P1. This is the version available to me from the support site.
