Need PowerShell Help With Contents in Brackets {}
TMADOCTHOMAS
Hello,
I've created Powershell scripts to export CIFS shares, iSCSI LUN mappings, and network information to CSV files. Those files are copied to a DR server so we will have configuration information available in a disaster.
This works well, however there are a few fields that don't transfer data to the spreadsheet. Specifically, fields that enclose data in brackets {}.
Here's an example: the command for exporting the list of subnets to a spreadsheet.
Get-NcNetSubnet -Controller $CLUSTER | select SubnetName,Subnet,Gateway,IPRanges | Export-Csv subnets.csv
When I run the command without the Export-Csv, the "IPRanges" field shows up like this in PowerShell:
{0.0.0.0-1.1.1.1}
With Export-Csv, it exports the results for this field like this:
System.String[]
I get similar results when I list network interfaces. The "DataProtocols" field encloses the results in {} which shows up wrong on the spreadsheet.
Has anyone run across this behavior? Is there a solution? Thanks in advance!
1 ACCEPTED SOLUTION
GidonMarcus
didn't look exactly on your case - i guess it's
http://blog.millersystems.com/powershell-exporting-multi-valued-attributes-via-export-csv-cmdlet/
Just to share that the way i do this type of export-import is with
ConvertTo-Json
Or
Export-CliXML
And then on the other site
ConverFrom-Json
OR
Import-CliXML
That gives very consistent data structure. and will also work with simple pipe sometimes.($Quota | Set-ncQuota)
i prefer the  CLIXML options. but they should both work just the same.
Gidi
Gidi Marcus (Linkedin) - Storage and Microsoft technologies consultant - Hydro IT LTD - UK
2 REPLIES 2
GidonMarcus
ConvertTo-Json
Or
Export-CliXML
ConverFrom-Json
OR
Import-CliXML
Gidi
TMADOCTHOMAS
Thank you @GidonMarcus! The link gave me just what I needed.
