Active IQ and AutoSupport Discussions
Fas2020 not booting,stuck at BMC login
SUJIT1215
Hi Guys, we have old Fas2020 in our lab.The login password was lost so i tried to go in the special boot menu to reset the password. I am connecting through a serial cable. I tried doing a power on/off several times of the netapp but it is stuck at the BMC login prompt screen. I tried running the below commands in the BMC login and below is the output. Please help..
re-init time           [bmc.reset.power:notice]: Hard reset by external power-cycle.
BMC Release 1.1
Press ^G to enter BMC command shell
pre-init time           [bmc.asup.queue:err]: Too many outstanding, undelivered AutoSupport messages - throttling.  *******THIS IS WHERE IT IS STUCK********
=== OEMCLP v1.0.0 BMC v1.1 ===
bmc shell -> system show
power          :on
fault          :pcm
reset          :off
product        :FAS2020
serial-number  :30000351
firmware       :primary
mellanox       :normal
nvmem          :enabled
bmc shell -> system power status
power          :on
1 ACCEPTED SOLUTION
baijulal
Your issue could be this
https://kb.netapp.com/support/index?page=content&id=2015921
this article is no longer active since the Platform is End of support
here is the solution from the Archive:
This affects all FAS2020, FAS2040, and FAS2050 systems.
Possible causes for BIOS boot failures are:
Loose connection of NVMEM battery
Dirty shutdown >>72+ hrs (depleting the battery completely) before powering
the system back on.
Improper DIMM replacement procedure
DIMM errors related to defective DIMM
DIMM errors related to memory control circuitry
Solution
1. Run the following commands in the BMC shell:
bmc shell -> priv set advanced
bmc shell*-> system reset backup
bmc shell*-> system power cycle
This will cause a dirty shutdown of your appliance. Continue? [y/N] y
17 REPLIES 17
aborzenkov
What happens if you press ^D to leave BMC shell?
SUJIT1215
It exits from the BMC Shell but does not proceed further.
bmc shell ->
aborzenkov
If you press return at this point?
SUJIT1215
Nothing happens if i press return or Ctrl C
baijulal
issue bmc> system console
and observe what promt is displayed,  system booted or on loader/cfe prompt?
SUJIT1215
bmc shell -> system console
Nothing happens after press return/enter or Ctrl C
baijulal
Can you try to ping the main IP,
Try ssh/telnet are you getting a login prompt?
SUJIT1215
The ping to the main IP is failing. (Request timed out)
I am not able to ssh/telnet.
baijulal
If this is a not a HA pair
be in bmc>system console menu
Power recycle the controller and wait for the boot messages to appear on the console
SUJIT1215
bmc shell -> system console menu
system console                Return to system console
bmc shell ->
pre-init time           [bmc.reset.power:notice]: Hard reset by external power-cycle.
BMC Release 1.1
pre-init time           [bmc.power.on.auto:notice]: Power off on reset detected; powering on...
pre-init time           [bmc.asup.send:notice]: Sending ASUP: CRITICAL: REBOOT (power loss).
pre-init time           [bmc.asup.crit:crit]: Press hotkey ^G to troubleshoot this problem.
pre-init time           [bmc.asup.smtp:err]: SMTP Client Error: Code 10, SMTP server IPv4 address is not configured
baijulal
I believe you will see the boot process now and option to enter special boot menu.
SUJIT1215
No , its back to the BMC login prompt
SUJIT1215
I am going to give it some time to load/boot. Will let you know on Monday. Thanks and have a nice weekend.
baijulal
Not sure what is happening, suggest to open a a tech case with NetApp.
baijulal
the system back on.
Solution
SUJIT1215
Thanks a ton Baiju !!!!.  The link you sent solved the issue. I was able to boot up the fas2020.
Appreciate your help !!!
ajebertowski
If I can't get access to the KB site, but I'm experiencing exactly the same problem on another system, what were the steps?
