Active IQ and AutoSupport Discussions
Retrieve NFS Usage Stats by Volume
sfoubister
Hi all
I am trying to get NFS usage stats by volume but cannot seem to find that information anywhere. I have had a poke around the Dashboard system on the Now site but still can only get that information at a filer level.
I saw on a forum posting that you can get that through the SDK. Does anyone know if this is true or how to do so?
Any help would be appreciated.
Thanks
Steve.
3 REPLIES 3
sfoubister
For anyone interested I have managed to resolve this issue by getting the information through the Operations Manager by running the "Volume Performance Summary" report.
Steve.
t_kumar
See if this helps anyway; not by volume , but by host wise
`nfsstat -l ` after setting `options nfs.per_client_stats.enable off`
shaunjurr
You could probably script something into mrtg/rrdtool by grabbing 'qtree stats <volname>' ... and if that exists there is probably an snmp OID as well...
I think a quick google search will lead you to some mrtg/rrdtool tools both here in the Community and elsewhere.
If you have Operations Manager, the Performance Advisor can be used to create some views too...
