Active IQ and AutoSupport Discussions
autosupport using https
eduard
Hi all,
I want to configure our autosupport to use https protocol, but without using any proxy, as our network dont have proxy. Below is our config of autusupport:
autosupport.cifs.verbose     off
autosupport.content          complete   (value might be overwritten in takeover)
autosupport.doit             MANAGEMENT_LOG
autosupport.enable           on         (value might be overwritten in takeover)
autosupport.from             postmaster (value might be overwritten in takeover)
autosupport.local_collection on         (value might be overwritten in takeover)
autosupport.mailhost         mailhost   (value might be overwritten in takeover)
autosupport.max_http_size    10485760   (value might be overwritten in takeover)
autosupport.max_smtp_size    5242880    (value might be overwritten in takeover)
autosupport.minimal.subject.id systemid   (value might be overwritten in takeover)
autosupport.nht_data.enable  on         (value might be overwritten in takeover)
autosupport.noteto                      (value might be overwritten in takeover)
autosupport.partner.to                  (value might be overwritten in takeover)
autosupport.payload_format   7z         (value might be overwritten in takeover)
autosupport.performance_data.doit DONT
autosupport.performance_data.enable on         (value might be overwritten in takeover)
autosupport.periodic.tx_window 1h         (value might be overwritten in takeover)
autosupport.retry.count      15         (value might be overwritten in takeover)
autosupport.retry.interval   4m         (value might be overwritten in takeover)
autosupport.support.enable   on         (value might be overwritten in takeover)
autosupport.support.proxy               (value might be overwritten in takeover)
autosupport.support.put_url  support.netapp.com/put/AsupPut (value might be overwritten in takeover)
autosupport.support.to       [email protected] (value might be overwritten in takeover)
autosupport.support.transport https      (value might be overwritten in takeover)
autosupport.support.url      support.netapp.com/asupprod/post/1.0/postAsup (value might be overwritten in takeover)
autosupport.throttle         on         (value might be overwritten in takeover)
autosupport.to                          (value might be overwritten in takeover)
autosupport.validate_digital_certificate on         (value might be overwritten in takeover)
Upon checking on the myautosupport site, we still don't have the autosupport logs.
Hope you can help.
Thanks.
Eduard
2 REPLIES 2
amans
Hi Eduard.
Can we have SN# or System ID ?
Also, if the OS is 7 Mode then provide me ([email protected]) the output of these commnands:
rdfile /etc/messages
rdfile /etc/rc
Thanks,
Aman
eduard
Thank you amans. I will email you the details.
