EF & E-Series, SANtricity, and Related Plug-ins
SanTricity - delay lag in SMcli running
josef_dvoracek
Hi all, did you seen long delay when run SMcli?
#time SMcli storagename -c "show storageArray;"
{loong delay}
Performing syntax check...
Syntax check complete.
Executing script..
Storage array profile
{long delay}
Script execution complete.
SMcli completed successfully.
real2m9.473s
user0m3.750s
sys 0m0.220s
version of SANtricity ES Storage Manager is 10.86.0G00.0013
Message was edited by: Josef Dvoracek
2 REPLIES 2
sunitao
The delay is dependent on the network connection and thus can vary. It can also vary for different commands. The above command should be quick
can you clarify more on below?can you explain what you mean by 'real', 'user', 'sys'?Are they using same network connection.
real2m9.473s
user0m3.750s
sys 0m0.220s
jamalb
Hi Josef,
Would you be able to give it a try with -quick option please.
Example: SMcli storagename -c "show storageArray;" -quick
Thanks,
CSE Team.
