EF & E-Series, SANtricity, and Related Plug-ins
Use DE212C/DE224C disk shelf as JBOD?
np-mast
Hello out there,
I am considering to repurpose old DE212C/DE224 disk shelfes from a E2800 system as a JBOD on standard x86 Linux/Windows servers with a SAS HBA.
Does anyone have experience with something like that?
1 ACCEPTED SOLUTION
AlexDawson
Hi there!
Plenty of people have done it with the DS4243/DS4246 - I don't see there's a reason it wouldn't work with the DE212C/DE224C shelves, they are effectively the same as the ONTAP ones from a technical point of view.
Check out https://reddit.com/r/homelab for examples
Hope this helps!
1 REPLY 1
AlexDawson
Hi there!
Hope this helps!
