General Discussion
Can XCP used for move DP volume to another aggregate?
Shaw_HM
Our customer has several FAS8300 and FAS2750 systems, using SnapMirror to protect volumes onto a FAS2720. All the destination DP volumes corresponding to the volumes on the FAS2750 are located on the FAS2720’s aggr_01_SAS_1. Now that this aggregate has run out of space, can some of the DP volumes be migrated to another aggregate aggr_02_SAS_1 using XCP?
If the current aggregate is already full, are there any other methods to migrate the DP volumes?
1 ACCEPTED SOLUTION
Sergey_Osipov
why the question is about XCP?
you can simply use vol move
2 REPLIES 2
Shaw_HM
Anyone help pls
Sergey_Osipov
