General Discussion
Problem with MySQL 8.0.x and NetApp snapshot folder
VitoMacDoc01
I am migrating old CentOS VMs running MySQL 5.x to MySQL 8.0.x that will run on Rocky 8 or 9.
I am installing mysql 8.0.x on the CentOS first, so I can verify all database files are updated and working.
Mysql 8 keeps reading the NetApp .snapshot folder as databases and throwing errors and stopping.
For some reason, this was not an issue in Mysql 5.x.
I did some research and I believe mysql 8 does not have the ignore directory setting anynore
Has anyone had and solved this issue ?
Thank you.
1 ACCEPTED SOLUTION
Sergey_Osipov
Please bear in mind that
  • Explicit access to .snapshot directory is still allowed
  • Clients that explicitly access the .snapshot directory will still show the multiple .snapshot mounts
Meaning volume needs to be remounted after a change
Another option is simply disabling snapdir-access at all
Additionally not even sure what AI suggested to you - feels like not a real advise
4 REPLIES 4
Sergey_Osipov
https://kb.netapp.com/on-prem/ontap/da/NAS/NAS-KBs/A_Linux_system_running_kernel_2.6x_creates_a_mount_point_when_accessing_the_.snapshot_directory_via...
Modern Linux clients identifies the .snapshot directory as a different filesystem, and thus as a different mount point
VitoMacDoc01
Thank you for this information, it is very helpful.  I did not know 9.5 had this option.
Another solution I read from an AI site is to put all data into a sub directory that does not have the .snapshot folder.  Seems like a very simple solution.  Data should still get snap saved.
Thank you  !!!!!  Very much appreciated !!!!
Sergey_Osipov
VitoMacDoc01
Actually, the AI suggestion was most helpful.
Instead of putting mysql data into the root level of the share which has .snapshot, create a sub directory
instead of /mysql/database, move to /mysql/database/data or something similar
I understand about remounting after change and browsing if needed.
Thank you again, very helpful.
