General Discussion
Create volume on root Aggregate (FAS 8040 cDot)
Anonymous
Hello Community,
Is it possible to create volume on root aggregate? If yes, how ?
When I try to create volume on root aggregate via OCSM, I get below error,
Any help would be appreciated,
Thank you,
Mert
1 ACCEPTED SOLUTION
robverhoeven
Short answer, no it is not supported!
Root aggregate is reserved voor OS, config, logging etc....no user data.
See this link: https://docs.netapp.com/ontap-9/index.jsp?topic=%2Fcom.netapp.doc.dot-cm-sag%2FGUID-A60F4F83-0034-4DB8-838B-06E9D4BEF9A4.html
Kind regards, Rob
2 REPLIES 2
robverhoeven
Kind regards, Rob
Anonymous
Short answer, thank you Rob!
