General Discussion
FAS 2040 slow speed copying ISCSI
Hosting
Hello everyone, I have a laboratory with a FAS2040 and a ds4243 disk shelf
FAS2040 12 X 600GB SAS (4 gigabit ethernet ports)
DS4243 24 X 600GB SAS
Cisco switches
Dell r815 server with Windows 2008r2 (2 gigabit ethernet ports)
In all the equipment Jumbo frame is config // mtu size 9000
lun1 disk E:
lun2 disk S:
I have two lun's mounted on a Windows 2008r2 server (500GB each one) I'm using ISCSI with the netapp DSM software
copying files to disk is fast 200-300 MB/S the problem is when copying files from one disk to another (S: to E 🙂 the speed drops to 10 MB/S the same happens if I copy files to local disks they are SSD
I don't see performance problems in storage counters
Can somebody help me.
1 ACCEPTED SOLUTION
aladd
I know it has been several months, but I wanted to reach out to you on this question.
Depending on disk speeds write operations are acknowledged once writes are received by NVRAM, however reads may be slower as it requires data to be read directly from the slower SAS disk rather than from memory.
You can see performance statistics using the sysstat command for 7-mode or qos statistics output from Clustered ONTAP.
2 REPLIES 2
aladd
Hosting
Hi thanks for your replay,  I was able to fix it  the solution was to set on the switch flow control to full and in the end host to send
