General Discussion
MCC plan test
patriceberanger
Hi all,
I'm looking for a document who relate step by step all the plan test for a 4 node fabric metrocluster.
I already used this doc, and can't find it today.
If someone can tell me where to find it, it will be great.
Otherwise ... I will spend so many time to write ...
Thanks for all
Patrice
1 REPLY 1
vpenev
Hi Patrice,
From the description provided, I would assume that this document might be helpful - http://docs.netapp.com/ontap-9/index.jsp?topic=%2Fcom.netapp.doc.dot-mcc-inst-cnfg-fabric%2FGUID-B90660F2-729C-4359-BBAC-D17A5232E6F7.html&resultof=%2...
As you can see on the left side you have a lot of other information available as well, in case you need something more specific.
