General Discussion
Ontap Select 9 and Commvault IntelliSnap can they work like a FAS hardware?
nl-sas
We have a question for a partner, Commvault Intellisnap can work fine with Ontap 9.x .
https://199.255.244.206/commvault/v11/article?p=37169.htm
But can work fine with Ontap Selec??
Thank you for your answers!!!
1 REPLY 1
AlexDawson
Hi there!
From our point of view, ONTAP Select has NDMP functionality and works like hardware ONTAP, so there's no reason we can see that it shouldn't work, but compatibility of third party products is up to the third party vendor to certify. You would need to contact commvault to find out if they would support this configuration.
Hope this helps!
