General Discussion
Power-Fan Canister part number in E2800 Shelves
karmad
Hello,
Сould you tell me the part number Power-Fan Canister in E2812 shelf and in DE224C drive shelf.
The equipment is only ordered, so it will not be able to connect to it and serial number do not have yet.
1 ACCEPTED SOLUTION
COMITSUPPORT
The Mktg Part no is X-5726A-00
The E2812 or the E2824 controller shelf consists with two power-fan canisters. The DE212C and DE224C drive shelves are identical, but they include I/O modules (IOMs) instead of controller canisters.
1 REPLY 1
COMITSUPPORT
