General Discussion
Supported Cisco 10G RJ45 Transceiver on FAS2750
Zulhadi
Hi all,
Just for asking for the supported 10G RJ45 transceiver for FAS2750 for the UTA port of e0e and e0f.  I have the cisco 10G RJ45 transceiver (as per below model). Can check whether supported on the FAS2750? Thanks
1 REPLY 1
Gmox
Hello,
has you already seen, this 10gb RJ45 SFP are not in supported SFP for FA2750 on HWU.
If you have one, can you directly perform a test and check the status?
FAS2750 can have 2 types of controller:
- UTA
- RJ45 10GB
I'd like to say that it should work, but as no information from NetApp we can't validate that point.
