General Discussion
SFP Copper 10GB RJ-45 for UTA2 port on FAS2750
Zulhadi
Hi All,
I want to check here, is it any available/supported 10GB RJ-45 transceiver that can connect to current UTA2 port on the FAS2750 model? I've try search on the HWU universe, there is only available 1GB RJ-45 transceiver supported and none of 10GB supported.
Can anyone advise on this? We plan to use the port for the Snap Mirror LIF ports and we have a dedicated 10G ethernet port that we plan to use as private network for Snap Mirror replication.
-zul-
1 REPLY 1
AlexDawson
Hi!
Unfortunately all of the 10GBaseT SFPs that were on the market when the FAS2750 came out were too high power/heat to be supportable in there. There have been some newer ones released since which might be ok, but they won't be supported. I would suggest an external media converter box and DAC cables would be the most reliable option.
