ONTAP Discussions
DFM - OnCommand - connection issue
gdefevere
Hello,
I've a controller that doesn't connect correctly with dfm/oncommand. Not through http, nor through https
Controller status message in dfm: Host Communication Failed
dfm host diag results.
XML (https port 443)  Error Can't connect to host (err=10061).
XML (http port 80)  Error HTTP POST - Unable to send the API request(err=10054).
It's not the firewall blocking something in between (all ports open for test). The partner in the metroclusters works perfect !
KR, Geert
1 ACCEPTED SOLUTION
gdefevere
Tnx for the feedback. This was all been verified.
Solution:
filer> options ssl.enable off
filer> secureadmin setup ssl
filer> options ssl.enable on
Found an additional link when trying to logon with oncommand system manager. This brought the error "com.netapp.nwf.client.communication.ResponseException".
3 REPLIES 3
paul_wolf
Have you compared the output of the dfm host diag from the controller that is OK to the one that is not?  Are there any differences?
Any chance you could post the output here?
Also, have you looked at the Controller Settings in Operations Manager to verify that there aren't any differences in Login Protocol, credentials, etc?
gdefevere
Solution:
mbeattie
Hi All,
In addition to the SSL configuration if you get the following error from a running a dfm host diag:
XML (http port 80)     Can't connect to host (err=10061).
Check the storage controller to see if the following options are ON.
options httpd.admin.ssl.enable
options httpd.admin.enable (XML http port 80)
https://kb.netapp.com/support/index?page=content&id=2016502&locale=en_US
As per the notes in the KB article:
Notes:
  • vFiler units are discovered through XML to the hosting storage systems. Therefore, if XML is not enabled to the hosting storage system (hostLogin is not set), the vFiler discovery and monitoring will be disabled for that storage system.
/matt
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
