ONTAP Discussions
Disk encrypt revert_original from maintenance mode responds with a root volume error
Mattponca
I had posted a few months ago about a circumstance that required reverting SEDs to their factory state in maintenance mode:
https://community.netapp.com/t5/AFF-NVMe-EF-Series-and-SolidFire-Discussions/Revert-SED-to-manufacturer-s-state-from-maintenance-mode/m-p/164196
I've recently had the opportunity to try it out, and I receive a "no usable root volume found" upon execution of the disk encrypt revert_original command in maintenance mode, and the disks remain in a failed state-- subsequent "disk unfail" commands also have no effect.  Although I fully expect there not to be a root volume in place and realize there's truth to the message, I would expect that I would have unfailed disks after both of the commands I used were issued.
Is there another step I'm missing here?
1 REPLY 1
andris
You might want to get official guidance via a technical case.
That said, this message is informative -- "no usable root volume found".
You probably need to have one NSE spare disk that isn't locked to create a 1-disk temporary root on it -- before you attempt the "revert_original" command.
