ONTAP Discussions
Doubt with volume nfs and cifs
santunez_cl
Hello Guys
Excuse my question but I have some doubts regarding mounting NFS and CIFS volumes
I have Ontap 9.7 which I have NFS and CIFS configured.
I have created Storage VM for cifs and nfs, and then in the case of NFS I have created a 1TB volume to present to a Linux Centos Server.
The volume mounts without problems, but I have doubts with the mount, since when executing a showmount -e with the 2 NFS IPs that I configure for each node it shows me the volume, but it is not clear to me if I should mount with both IPs or only one, additionally, if there is a way to only have one VIP IP to mount the volume
With CIFS I have the same question, how to make the mount of share with both IP or only one
Thanks for your help
1 ACCEPTED SOLUTION
TMACMD
NFS and CIFS only clients only mount/share over ONE IP at a time per mount/share.
You can setup the multiple IP addresses in DNS for Round-robin load balancing and use a name instead of an IP. This will at least use the network on both NetApp controllers.
ONTAP has an On-Box DNS load balancing mechanism that distributes IP addresses via internal load calculations.
I know with NFS, you can specify multiple IP addresses for failover purposes, but ONTAP does that anyway.
2 REPLIES 2
TMACMD
Netapp_maniac
Yes , You can use 1 IP in case of NFS and CIFS .
