ONTAP Discussions
From ONTAP NetApp without Volume Encryption (nodar) to version with Volume Encryption
alessice
Hi,
I have some FAS2554 with 9.5 that I need to upgrade to ONTAP 9.7. I don't know why but I have always installed ONTAP without Volume Encryption (nodar file).
Now I need Volume Encryption because new FAS2720 have it and I would like to use on all FAS.
On FAS2554 can I just upgrade ONTAP version with Volume Encryption using the right file?
So the upgrade put for FAS2554 will be:
9.5P19 nodar to 9.7P18 standard (with NetApp Volume Encryption)
Thanks
1 ACCEPTED SOLUTION
darb0505
Hi @alessice,
Yes you can upgrade from a ONTAP without Volume Encryption (nodar) to one that has Volume Encryption.
Feel free to reference KB: Can we upgrade ONTAP from NODAR to DAR image?
The KB has some additional links that will help you with the upgrade.
Let us know if you have any other questions or run into issues.
Thanks,
Brad
Team NetApp
2 REPLIES 2
darb0505
Hi @alessice,
Thanks,
Brad
Team NetApp
TMACMD
Well, sorry to bust your bubble here, the encryption is not supported on the Fas2554 platform
 do even if you did upgrade, you would not be able to use it
