ONTAP Discussions
How can I destroy a volume that contain a busy snapshot ?
psjl_storage
I need your help.
I have issue that can't destroy the volume which has a busy snapshot for OSSV.
Let me explain waht I did.
# I tried to offline a volume for destroy.
vol offline FA01_Vol11
The following prevents offline of volume FA01_Vol11
        qtree replication destination
vol offline: Volume is in use by other operations. (FA01_Vol11).
# Then I deleted all snapshot except busy one.
snap list  FA01_Vol11
olume FA01_Vol11
working...
  %/used       %/total  date          name
  1% ( 1%)    1% ( 1%)  Feb 24 01:12  JPTDC1NS02(2014870149)_FA01_Vol11-base.54 (busy,snapvault)
# The snapshot is used by OSSV.
To delete the snapshot, I need to release OSSV.
However the filer is the secondary system and "release" have to run on the source system.
The source system is already decommissioned.
What should I do ?
Do you have any idea to delete the snap shout forcefully in busy status ?
I also let you now the OSSV status.
ns02 snapvault status -l
Snapvault is ON.
Source:                 10.26.6.101:E:
Destination:            JPTDC1NS02:/vol/FA01_Vol11/YC0WS101-E
Status:                 Idle
Progress:               -
State:                  Snapvaulted
Lag:                    1452:19:12
Mirror Timestamp:       Sun Feb 23 01:05:04 JST 2014
Base Snapshot:          JPTDC1NS02(2014870149)_FA01_Vol11-base.54
Current Transfer Type:  Update
Current Transfer Error: could not read from socket
Contents:               Transitioning
Last Transfer Type:     Update
Last Transfer Size:     4933076 KB
Last Transfer Duration: 03:45:24
Last Transfer From:     10.26.6.101:E:
Best regards.
1 REPLY 1
vreddypalli
Hi,
Try to turn OFF and ON the option "snapvault.enable" on the filer when there are no snapvault transfers happening.  Now try deleting the volume.
Regards,
Vijay R
