ONTAP Discussions
How to find memory utilization and throughput of storage system using ONTAP API??
VISHWASTALULE
Hi,
I am using netapp (nmsdk) ONTAP API to collect storage information.
I am able to connect information of lun, aggregates, disks etc.
I want to calculate memory utilization and throughput of storage system.
I want object name or api name,counter name to which I do query and  get above mentioned fields.
Any help/ workout will be great favor.
Thank you in advance
1 REPLY 1
georgevj
are you refering to these?
perf-object-counter-list-info
perf-object-get-instances
perf-object-get-instances-iter-end
perf-object-get-instances-iter-next
perf-object-get-instances-iter-start
perf-object-instance-list-info
perf-object-instance-list-info-iter-end
perf-object-instance-list-info-iter-next
perf-object-instance-list-info-iter-start
perf-object-list-info
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Cannot find the answer you need? No need to open a support case - just CHAT and we’ll handle it for you.
