ONTAP Discussions
Strange output for 'sasadmin shelf' command
ItsIrbFiler
Hello.
I post this as a question just in case other people have experienced something similar and also looking for an explanation. I'm also trying to confirm that everything in my system is OK or if not, perhaps someone can tell me how I can fix it.
We are running Data ONTAP 8.1 7-mode in an active-active cluster. We recently added a new DS4243 shelf in our storage infrastructure. We opened two loops to insert this new shelf but the command 'sasadminshelf' shows an output that seems strange. For one of the loops the command shows shelvs with IDs from 0 to 7 and for the complementary loop it shows shelves from 6 to 0 and then 7, when we expected shelves with IDs from 7 to 0 (we are not sure about this). We attach the output of the 'sasadmin shelf' command for both loops, it is equivalent for both controllers (active-active). At the end we also added the output of the command 'sasadmin expander_map' for both loops/adapters. I have to say that we run 'sasadmin adapter_reset' on the adapter with weird shelf order but it caused no effect.
filer2> sasadmin shelf 0a
Expanders on channel 0a:
0 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
1 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
2 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
3 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
4 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
5 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
6 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
7 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
filer2> sasadmin shelf 3a
Expanders on channel 3a:
6 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
5 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
4 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
3 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
2 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
1 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
0 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
7 | 0 | 1 | 2 | 3 |
| 4 | 5 | 6 | 7 |
| 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 |
| 16 | 17 | 18 | 19 |
| 20 | 21 | 22 | 23 |
filer2> sasadmin expander_map 0a
Level 1: WWN 50050..., ID 0, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot A
Level 2: WWN 50050..., ID 1, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot A
Level 3: WWN 50050..., ID 2, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot A
Level 4: WWN 50050..., ID 3, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot A
Level 5: WWN 50050..., ID 4, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot A
Level 6: WWN 50050..., ID 5, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot A
Level 7: WWN 50050..., ID 6, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot A
Level 8: WWN 50050..., ID 7, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot A
filer2> sasadmin expander_map 3a
Level 2: WWN 50050..., ID 6, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot B
Level 3: WWN 50050..., ID 5, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot B
Level 4: WWN 50050..., ID 4, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot B
Level 5: WWN 50050..., ID 3, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot B
Level 6: WWN 50050..., ID 2, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot B
Level 7: WWN 50050..., ID 1, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot B
Level 8: WWN 50050..., ID 0, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot B
Level 1: WWN 50050..., ID 7, Serial Number ' SHX09...', Product 'DS424IOM3 ', Rev '0152', Slot B
filer2>
9 REPLIES 9
aborzenkov
You made a mistake cabling channel B. You connected shelf 7 to shelf 1 instead of connecting it to shelf 6.
ItsIrbFiler
Don't know exactly what happened. Everything worked fine although this output was weird. We checked the cabling with certified professionals from NetApp partner and everything seem to be properly connected.
A few weeks ago we added two new shelves to the loop so we have a 10 shelves loop. One of the controllers died twice due to an unexpected network problem and after that the output for the command 'sasadmin shelf 3a' is correct in both contollers. The original issue does not worry anymore but I don't know exactly ho has this been fixed.
Anyway in a few days we are going to do ONTAP upgrade to fix some bugs and I hope we can better tune our systems.
DavidAtIBM
We recently added a DS4246 shelf to an existing stack on a N6270 (FAS3270) system running ONTAP 8.2P6 and saw exactly the same behavior where the sasadmin shelf and sasadmin expander_map output show the newly added shelf out of order, but only on one of the adapters. All the cabling was correct and everything checks out fine in the Config Advisor. Hopefully we don't have to have an outage like you did to correct it. Though it appears to be merely a cosmetic bug, I'd like to know the cause and if there's a way to avoid it in future installs.
aborzenkov
Could you post sasadmin output?
DavidAtIBM
Sure, here's that output - shelf 8 was the one that we added to the 4a/6b stack after shelf 7:
filer1> sasadmin shelf
   0 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
     | DD | DD | DD | DD |
   1 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
     | 12 | 13 | 14 | 15 |
     | 16 | 17 | 18 | 19 |
     | 20 | 21 | 22 | 23 |
   2 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
   3 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
   6 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
Expanders on channel 0b:
Cannot Complete operation on channel 0b; Status Not Available.
Expanders on channel 4a:
   7 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
     | 16 | 17 | DD | DD |
   5 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
   4 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
   8 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | DD | DD |
Expanders on channel 4b:
   6 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
   3 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
   2 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
   1 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
   0 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
Expanders on channel 4c:
Cannot Complete operation on channel 4c; Status Not Available.
Expanders on channel 4d:
Cannot Complete operation on channel 4d; Status Not Available.
Expanders on channel 6a:
Cannot Complete operation on channel 6a; Status Not Available.
Expanders on channel 6b:
   4 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
   5 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
   7 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | 10 | 11 |
   8 |  0 |  1 |  2 |  3 |
     |  4 |  5 |  6 |  7 |
     |  8 |  9 | DD | DD |
Expanders on channel 6c:
Cannot Complete operation on channel 6c; Status Not Available.
Expanders on channel 6d:
Cannot Complete operation on channel 6d; Status Not Available.
filer1> sasadmin expander_map
Level  1: WWN 50050cc103efc03f, ID  0, Serial Number ' SHJ00000000EFA6', Product 'DS424IOM3       ', Rev '0181', Slot B
Level  2: WWN 50050cc1047aa4ff, ID  1, Serial Number ' SHJ00000000EFA1', Product 'DS424IOM3       ', Rev '0181', Slot B
Level  3: WWN 50050cc1047a0cff, ID  2, Serial Number ' SHJ00000000EFA3', Product 'DS424IOM3       ', Rev '0181', Slot B
Level  4: WWN 50050cc1049e4a3f, ID  3, Serial Number ' SHJ00000000EFB6', Product 'DS424IOM3       ', Rev '0181', Slot B
Level  5: WWN 50050cc104d6da3f, ID  6, Serial Number ' SHJMS0000015DE0', Product 'DS424IOM3       ', Rev '0181', Slot B
Level  2: WWN 500a0980011bd67f, ID  7, Serial Number ' SHJ00000001258C', Product 'DS424IOM6       ', Rev '0173', Slot A
Level  3: WWN 500a098001ebba3f, ID  5, Serial Number ' SHU0946862G0J45', Product 'DS424IOM6       ', Rev '0173', Slot A
Level  4: WWN 500a098001aec9ff, ID  4, Serial Number ' SHJ000000008237', Product 'DS424IOM6       ', Rev '0173', Slot A
Level  1: WWN 500a098004638bbf, ID  8, Serial Number ' SHJ00000000ADB6', Product 'DS424IOM6       ', Rev '0173', Slot A
Level  1: WWN 50050cc104d7f77f, ID  6, Serial Number ' SHJMS0000015DE0', Product 'DS424IOM3       ', Rev '0181', Slot A
Level  2: WWN 50050cc1049e427f, ID  3, Serial Number ' SHJ00000000EFB6', Product 'DS424IOM3       ', Rev '0181', Slot A
Level  3: WWN 50050cc1047aa6bf, ID  2, Serial Number ' SHJ00000000EFA3', Product 'DS424IOM3       ', Rev '0181', Slot A
Level  4: WWN 50050cc1047a703f, ID  1, Serial Number ' SHJ00000000EFA1', Product 'DS424IOM3       ', Rev '0181', Slot A
Level  5: WWN 50050cc104b95abf, ID  0, Serial Number ' SHJ00000000EFA6', Product 'DS424IOM3       ', Rev '0181', Slot A
Level  1: WWN 500a098001b6133f, ID  4, Serial Number ' SHJ000000008237', Product 'DS424IOM6       ', Rev '0173', Slot B
Level  2: WWN 500a098001f2297f, ID  5, Serial Number ' SHU0946862G0J45', Product 'DS424IOM6       ', Rev '0173', Slot B
Level  3: WWN 500a0980011c077f, ID  7, Serial Number ' SHJ00000001258C', Product 'DS424IOM6       ', Rev '0173', Slot B
Level  4: WWN 500a098001ad593f, ID  8, Serial Number ' SHJ00000000ADB6', Product 'DS424IOM6       ', Rev '0173', Slot B
aborzenkov
It really looks like channel A is miscabled. To give definitive answer "sysconfig -a" and "environment status shelf" would be needed (they show SAS cables serial numbers) - unless you are using optical connection.
DavidAtIBM
I'm fairly confident we have this cabled correctly. To be up front, I was not the one on site doing the cabling, but I have worked with the same CE before (installing shelf 7, in fact) and have found him to be very competent. Here is the relevant output from the sysconfig -a and environment status shelf for both channels. Looking it over myself, I did not see any anomalies. Please let me know if you do.
        slot 4: SAS Host Adapter 4a (PMC-Sierra PM8001 rev. C, SAS, <UP>)
                MFG Part Number:    USI 6086-000010-07 rev. MP V4.10
                Part number:        111-00341+F2
                Serial number:      ST063CAP0BT
                Date Code:          20121023
                Firmware rev:       01.11.00.00
                Base WWN:           5:00e004:000232a:68
                Phy State:          [0] Enabled, 6.0 Gb/s
                                    [1] Enabled, 6.0 Gb/s
                                    [2] Enabled, 6.0 Gb/s
                                    [3] Enabled, 6.0 Gb/s
                QSFP Vendor:        Molex Inc.
                QSFP Part Number:   112-00178+A0
                QSFP Type:          Passive Copper 5m ID:01
                QSFP Serial Number: 331520818
                04.0 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0447167)
                04.1 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0473194)
                04.2 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0473219)
                04.3 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0463671)
                04.4 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0446011)
                04.5 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0472672)
                04.6 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0469649)
                04.7 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0469519)
                04.8 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0449432)
                04.9 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0465683)
                04.10: NETAPP   X306_WMANT02TSSA NA01 1695.4GB 512B/sect (WD-WCAY01141917)
                04.11: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0469587)
                04.12: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0473480)
                04.13: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0469522)
                04.14: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0473395)
                04.15: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0443615)
                04.16: NETAPP   X306_HJUPI02TSSM NA06 1695.4GB 512B/sect (BFHV9SMF)
                04.17: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0473094)
                04.18: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0472512)
                04.19: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0469615)
                04.20: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0446811)
                04.21: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0473391)
                04.22: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0472508)
                04.23: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0473283)
                05.0 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAY04739288)
                05.1 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0414331)
                05.2 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0412304)
                05.3 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0413717)
                05.4 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0396119)
                05.5 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0413207)
                05.6 : NETAPP   X306_WMANT02TSSA NA01 1695.4GB 512B/sect (WD-WCAY01634063)
                05.7 : NETAPP   X306_HMARK02TSSM NA04 1695.4GB 512B/sect (YGKKKYKG)
                05.8 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0396246)
                05.9 : NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0414438)
                05.10: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0412401)
                05.11: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0421198)
                05.12: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0312531)
                05.13: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0422983)
                05.14: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0312702)
                05.15: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0433525)
                05.16: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0312641)
                05.17: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0436095)
                05.18: NETAPP   X306_HMARK02TSSM NA04 1695.4GB 512B/sect (YGKT6U0G)
                05.19: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0425669)
                05.20: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0425863)
                05.21: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0426326)
                05.22: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0435959)
                05.23: NETAPP   X306_WMANT02TSSM NA08 1695.4GB 512B/sect (WD-WMAUR0421066)
                07.0 : NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJGD7JA)
                07.1 : NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJALKLA)
                07.2 : NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJGD6EA)
                07.3 : NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJG886A)
                07.4 : NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJG7SWA)
                07.5 : NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJG4Y2A)
                07.6 : NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJG7PXA)
                07.7 : NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJG96XA)
                07.8 : NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJG4WJA)
                07.9 : NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJG96TA)
                07.10: NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJGDL3A)
                07.11: NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJG4XZA)
                07.12: NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJGBAVA)
                07.13: NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJG91ZA)
                07.14: NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJG88UA)
                07.15: NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJDUN4A)
                07.16: NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJG5JVA)
                07.17: NETAPP   X306_HMARK02TSSA NA01 1695.4GB 512B/sect (YFJEJLAA)
                08.0 : NETAPP   X306_HJUPI02TSSM NA06 1695.4GB 512B/sect (B9JEVW6F)
                08.1 : NETAPP   X306_HJUPI02TSSM NA06 1695.4GB 512B/sect (B9HBVE3F)
                08.2 : NETAPP   X306_HJUPI02TSSM NA06 1695.4GB 512B/sect (B9JA76XF)
                08.3 : NETAPP   X306_HJUPI02TSSM NA06 1695.4GB 512B/sect (B9JEYBAF)
                08.4 : NETAPP   X306_HJUPI02TSSM NA06 1695.4GB 512B/sect (B9HBSGJF)
                08.5 : NETAPP   X306_HJUPI02TSSM NA06 1695.4GB 512B/sect (B9HBLG3F)
                08.6 : NETAPP   X306_HJUPI02TSSM NA06 1695.4GB 512B/sect (B9JEARYF)
                08.7 : NETAPP   X306_HJUPI02TSSM NA06 1695.4GB 512B/sect (B9JAJ9PF)
                08.8 : NETAPP   X306_HJUPI02TSSM NA06 1695.4GB 512B/sect (B9JET7NF)
                08.9 : NETAPP   X306_HJUPI02TSSM NA06 1695.4GB 512B/sect (B9JEZJYF)
                Shelf   4: IOM6  Firmware rev. IOM6 A: 0173 IOM6 B: 0173
                Shelf   5: IOM6  Firmware rev. IOM6 A: 0173 IOM6 B: 0173
                Shelf   7: IOM6  Firmware rev. IOM6 A: 0173 IOM6 B: 0173
                Shelf   8: IOM6  Firmware rev. IOM6 A: 0173 IOM6 B: 0173
        slot 6: SAS Host Adapter 6b (PMC-Sierra PM8001 rev. C, SAS, <UP>)
                Serial number:      ST063CAP0BA
                Date Code:          20121023
                Base WWN:           5:00e004:000232b:2c
                Phy State:          [4] Enabled, 6.0 Gb/s
                                    [5] Enabled, 6.0 Gb/s
                                    [6] Enabled, 6.0 Gb/s
                                    [7] Enabled, 6.0 Gb/s
                QSFP Serial Number: 201620050
                        memory mapped I/O base 0xdee30000, size 0x10000
                        memory mapped I/O base 0xdee20000, size 0x10000
                        memory mapped I/O base 0x00000000dee10000, size 0x10000
                        memory mapped I/O base 0x00000000dee00000, size 0x10000
        Environment for channel 4a
        Number of shelves monitored: 4  enabled: yes
        Environmental failure on shelves on this channel? no
        Channel: 4a
        Shelf: 4
        SES device path: local access: 4a.04.99
        Module type: IOM6; monitoring is active
        Shelf status: normal condition
        SES Configuration, shelf 4:
         logical identifier=0x50050cc102028cbf
         vendor identification=NETAPP
         product identification=DS4246
         product revision level=0173
        Vendor-specific information:
         Product Serial Number: SHJ000000008237
        Status reads attempted: 186753; failed: 1
        Control writes attempted: 760; failed: 0
        Shelf bays with disk devices installed:
          23, 22, 21, 20, 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0
          with error: none
        Power Supply installed element list: 1, 4; with error: none
        Power Supply information by element:
          [1] Serial number: PMW8256200A9A1E  Part number: 0082562-20
              Type: 9C
              Firmware version: 0311  Swaps: 0
          [2] Serial number: <N/A>  Part number: <N/A>
              Type: <N/A>
              Firmware version: <N/A>  Swaps: 0
          [3] Serial number: <N/A>  Part number: <N/A>
              Type: <N/A>
          [4] Serial number: PMW8256200A984D  Part number: 0082562-20
              Type: 9C
        Voltage Sensor installed element list: 1, 2, 7, 8; with error: none
        Shelf voltages by element:
          [1] 5.11 Volts Normal voltage range
          [2] 12.22 Volts Normal voltage range
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [7] 5.15 Volts Normal voltage range
          [8] 12.22 Volts Normal voltage range
        Current Sensor installed element list: 1, 2, 7, 8; with error: none
        Shelf currents by element:
          [1] 11710 mA Normal current range
          [2] 7960 mA Normal current range
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [7] 9100 mA Normal current range
          [8] 9530 mA Normal current range
        Cooling Unit installed element list: 1, 2, 7, 8; with error: none
        Cooling Units by element:
          [1] 3000 RPM
          [2] 3520 RPM
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [7] 3000 RPM
          [8] 3000 RPM
        Temperature Sensor installed element list: 1, 2, 3, 4, 9, 10, 11, 12; with error: none
        Shelf temperatures by element:
          [1] 23 C (73 F) (ambient)  Normal temperature range
          [2] 31 C (87 F)  Normal temperature range
          [3] 32 C (89 F)  Normal temperature range
          [4] 40 C (104 F)  Normal temperature range
          [5] Unavailable
          [6] Unavailable
          [7] Unavailable
          [8] Unavailable
          [9] 31 C (87 F)  Normal temperature range
          [10] 41 C (105 F)  Normal temperature range
          [11] 31 C (87 F)  Normal temperature range
          [12] 31 C (87 F)  Normal temperature range
        Temperature thresholds by element:
          [1] High critical: 42 C (107 F); high warning: 40 C (104 F)
              Low critical:  0 C (32 F); low warning: 5 C (41 F)
          [2] High critical: 55 C (131 F); high warning: 50 C (122 F)
              Low critical:  5 C (41 F); low warning: 10 C (50 F)
          [3] High critical: 55 C (131 F); high warning: 50 C (122 F)
          [4] High critical: 70 C (158 F); high warning: 65 C (149 F)
          [5] High critical: Unavailable; high warning: Unavailable
              Low critical:  Unavailable; low warning:  Unavailable
          [6] High critical: Unavailable; high warning: Unavailable
          [7] High critical: Unavailable; high warning: Unavailable
          [8] High critical: Unavailable; high warning: Unavailable
          [9] High critical: 55 C (131 F); high warning: 50 C (122 F)
          [10] High critical: 70 C (158 F); high warning: 65 C (149 F)
          [11] High critical: 60 C (140 F); high warning: 55 C (131 F)
          [12] High critical: 60 C (140 F); high warning: 55 C (131 F)
        ES Electronics installed element list: 1, 2; with error: none
        ES Electronics reporting element: 1
        ES Electronics information by element:
          [1] Serial number: 8006054663  Part number: 111-00190+A0
              CPLD version: 23  Swaps: 0
          [2] Serial number: 8004738930  Part number: 111-00190+A0
        SAS connector attached element list: 1, 2, 3, 4; with error: none
        SAS cable information by element:
          [1] Vendor: Molex Inc.
              Type: QSFP passive copper 0.5-1.0m  ID: 01  Swaps: 0
              Serial number: 306520836  Part number: 112-00176+A0
          [2] Vendor: Molex Inc.
              Type: QSFP passive copper 5m  ID: 00  Swaps: 0
              Serial number: 129420101  Part number: 112-00178+A0
          [3] Vendor: Molex Inc.
              Type: QSFP passive copper 0.5-1.0m  ID: 00  Swaps: 0
              Serial number: 219520274  Part number: 112-00176+A0
          [4] Vendor: Molex Inc.
              Serial number: 201620050  Part number: 112-00178+A0
        ACP installed element list: 1, 2; with error: none
        ACP information by element:
          [1] MAC address: 00:A0:98:41:94:1A
          [2] MAC address: 00:A0:98:41:6F:1C
        SAS Expander Module installed element list: 1, 2; with error: none
        SAS Expander master module: 1
        Channel: 4a
        Shelf: 5
        SES device path: local access: 4a.05.99
        SES Configuration, shelf 5:
         logical identifier=0x50050cc102007e8b
         Product Serial Number: SHU0946862G0J45
          with error: none
          [1] Serial number: PMW82562001695C  Part number: 0082562-11
              Type: 9C
              Firmware version: 0305  Swaps: 0
              Type: <N/A>
              Type: <N/A>
          [4] Serial number: PMW82562001685C  Part number: 0082562-11
              Type: 9C
          [1] 5.07 Volts Normal voltage range
          [2] 12.14 Volts Normal voltage range
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [7] 5.07 Volts Normal voltage range
          [8] 12.26 Volts Normal voltage range
          [1] 7380 mA Normal current range
          [2] 8160 mA Normal current range
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [7] 8780 mA Normal current range
          [8] 6750 mA Normal current range
          [1] 2920 RPM
          [2] 1950 RPM
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [7] 3000 RPM
          [8] 2320 RPM
          [1] 24 C (75 F) (ambient)  Normal temperature range
          [2] 35 C (95 F)  Normal temperature range
          [3] 38 C (100 F)  Normal temperature range
          [4] 49 C (120 F)  Normal temperature range
          [5] Unavailable
          [6] Unavailable
          [7] Unavailable
          [8] Unavailable
          [9] 34 C (93 F)  Normal temperature range
          [10] 44 C (111 F)  Normal temperature range
          [11] 37 C (98 F)  Normal temperature range
          [12] 36 C (96 F)  Normal temperature range
          [1] Serial number: 8006448462  Part number: 111-00190+A0
          [2] Serial number: 8006483632  Part number: 111-00190+A0
              Type: QSFP passive copper 2m  ID: 00  Swaps: 0
              Serial number: 302920858  Part number: 112-00177+A0
              Type: QSFP passive copper 2m  ID: 01  Swaps: 0
              Serial number: 330321418  Part number: 112-00177+A0
          [1] MAC address: 00:A0:98:42:45:D4
          [2] MAC address: 00:A0:98:45:E3:F8
        Channel: 4a
        Shelf: 7
        SES device path: local access: 4a.07.99
        SES Configuration, shelf 7:
         logical identifier=0x50050cc10203932f
         Product Serial Number: SHJ00000001258C
        Status reads attempted: 186750; failed: 1
          with error: none
          [1] Serial number: PMW8256200F3605  Part number: 0082562-20
              Type: 9C
              Type: <N/A>
              Type: <N/A>
          [4] Serial number: PMW8256200F35FB  Part number: 0082562-20
              Type: 9C
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [1] 6750 mA Normal current range
          [2] 6870 mA Normal current range
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [7] 7180 mA Normal current range
          [8] 6870 mA Normal current range
          [1] 3900 RPM
          [2] 3000 RPM
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [7] 3000 RPM
          [8] 3070 RPM
          [1] 27 C (80 F) (ambient)  Normal temperature range
          [2] 34 C (93 F)  Normal temperature range
          [3] 29 C (84 F)  Normal temperature range
          [4] 38 C (100 F)  Normal temperature range
          [5] Unavailable
          [6] Unavailable
          [7] Unavailable
          [8] Unavailable
          [9] 29 C (84 F)  Normal temperature range
          [10] 42 C (107 F)  Normal temperature range
          [12] 24 C (75 F)  Normal temperature range
          [1] Serial number: 8003203677  Part number: 111-01070+A0
          [2] Serial number: 8003200455  Part number: 111-01070+A0
              Serial number: 114720197  Part number: 112-00178+A0
              Type: QSFP passive copper 5m  ID: 01  Swaps: 1
              Serial number: 114820065  Part number: 112-00178+A0
          [1] MAC address: 00:A0:98:33:D5:66
          [2] MAC address: 00:A0:98:33:D7:28
        Channel: 4a
        Shelf: 8
        SES device path: local access: 6b.08.99
        SES Configuration, shelf 8:
         logical identifier=0x50050cc1020330cf
         Product Serial Number: SHJ00000000ADB6
        Status reads attempted: 25242; failed: 0
        Control writes attempted: 104; failed: 0
          with error: none
        Power Supply installed element list: 2, 3; with error: none
          [1] Serial number: <N/A>  Part number: <N/A>
              Type: <N/A>
          [2] Serial number: PMW82562004D4B0  Part number: 0082562-11
              Type: 9C
          [3] Serial number: PMW8256200B79E3  Part number: 0082562-20
              Type: 9C
          [4] Serial number: <N/A>  Part number: <N/A>
              Type: <N/A>
        Voltage Sensor installed element list: 3, 4, 5, 6; with error: none
          [1] Unavailable
          [2] Unavailable
          [3] 5.15 Volts Normal voltage range
          [4] 12.38 Volts Normal voltage range
          [5] 5.07 Volts Normal voltage range
          [6] 12.07 Volts Normal voltage range
          [7] Unavailable
          [8] Unavailable
        Current Sensor installed element list: 3, 4, 5, 6; with error: none
          [1] Unavailable
          [2] Unavailable
          [3] 4530 mA Normal current range
          [4] 5350 mA Normal current range
          [5] 3710 mA Normal current range
          [6] 4290 mA Normal current range
          [7] Unavailable
          [8] Unavailable
        Cooling Unit installed element list: 3, 4, 5, 6; with error: none
          [1] Unavailable
          [2] Unavailable
          [3] 9520 RPM
          [4] 8700 RPM
          [5] 9000 RPM
          [6] 8100 RPM
          [7] Unavailable
          [8] Unavailable
        Temperature Sensor installed element list: 1, 2, 5, 6, 7, 8, 11, 12; with error: none
          [1] 29 C (84 F) (ambient)  Normal temperature range
          [2] 28 C (82 F)  Normal temperature range
          [3] Unavailable
          [4] Unavailable
          [5] 29 C (84 F)  Normal temperature range
          [6] 34 C (93 F)  Normal temperature range
          [7] 21 C (69 F)  Normal temperature range
          [8] 26 C (78 F)  Normal temperature range
          [9] Unavailable
          [10] Unavailable
          [11] 26 C (78 F)  Normal temperature range
          [12] 22 C (71 F)  Normal temperature range
          [3] High critical: Unavailable; high warning: Unavailable
          [4] High critical: Unavailable; high warning: Unavailable
          [5] High critical: 55 C (131 F); high warning: 50 C (122 F)
          [6] High critical: 70 C (158 F); high warning: 65 C (149 F)
          [7] High critical: 55 C (131 F); high warning: 50 C (122 F)
          [8] High critical: 70 C (158 F); high warning: 65 C (149 F)
          [9] High critical: Unavailable; high warning: Unavailable
          [10] High critical: Unavailable; high warning: Unavailable
        ES Electronics reporting element: 2
          [1] Serial number: 7901821907  Part number: 111-00190+B0
          [2] Serial number: 8005874274  Part number: 111-00190+A0
              Serial number: 331520818  Part number: 112-00178+A0
              Type: QSFP passive copper 5m  ID: 01  Swaps: 0
              Serial number: 331520825  Part number: 112-00178+A0
              Type: QSFP passive copper 5m  ID: 00  Swaps: 1
          [1] MAC address: 00:A0:98:74:12:26
          [2] MAC address: 00:A0:98:41:85:10
        SAS Expander master module: 2
        Shelf mapping (shelf-assigned addresses) for channel 4a:
          Shelf   4:  23  22  21  20  19  18  17  16  15  14  13  12  11  10   9   8   7   6   5   4   3   2   1   0
          Shelf   5:  23  22  21  20  19  18  17  16  15  14  13  12  11  10   9   8   7   6   5   4   3   2   1   0
          Shelf   7: XXX XXX XXX XXX XXX XXX  17  16  15  14  13  12  11  10   9   8   7   6   5   4   3   2   1   0
          Shelf   8: XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX   9   8   7   6   5   4   3   2   1   0
        Environment for channel 6b
        Channel: 6b
        Shelf: 4
        Status reads attempted: 186780; failed: 1
          with error: none
              Type: 9C
              Type: <N/A>
              Type: <N/A>
              Type: 9C
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [1] 11320 mA Normal current range
          [2] 7890 mA Normal current range
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [7] 8710 mA Normal current range
          [8] 9600 mA Normal current range
          [1] 3000 RPM
          [2] 3520 RPM
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [7] 3000 RPM
          [8] 3000 RPM
          [5] Unavailable
          [6] Unavailable
          [7] Unavailable
          [8] Unavailable
        Channel: 6b
        Shelf: 5
          with error: none
              Type: 9C
              Type: <N/A>
              Type: <N/A>
              Type: 9C
          [2] 12.18 Volts Normal voltage range
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [1] 7140 mA Normal current range
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [7] 8510 mA Normal current range
          [8] 6670 mA Normal current range
          [1] 3000 RPM
          [2] 1950 RPM
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [7] 3000 RPM
          [8] 2250 RPM
          [5] Unavailable
          [6] Unavailable
          [7] Unavailable
          [8] Unavailable
        Channel: 6b
        Shelf: 7
        Status reads attempted: 186777; failed: 1
          with error: none
              Type: 9C
              Type: <N/A>
              Type: <N/A>
              Type: 9C
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [1] 6480 mA Normal current range
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [1] 3900 RPM
          [2] 2920 RPM
          [3] Unavailable
          [4] Unavailable
          [5] Unavailable
          [6] Unavailable
          [7] 3000 RPM
          [8] 3070 RPM
          [5] Unavailable
          [6] Unavailable
          [7] Unavailable
          [8] Unavailable
        Channel: 6b
        Shelf: 8
        Status reads attempted: 25269; failed: 0
          with error: none
              Type: <N/A>
              Type: 9C
              Type: 9C
              Type: <N/A>
          [1] Unavailable
          [2] Unavailable
          [4] 12.34 Volts Normal voltage range
          [7] Unavailable
          [8] Unavailable
          [1] Unavailable
          [2] Unavailable
          [4] 5310 mA Normal current range
          [5] 3780 mA Normal current range
          [7] Unavailable
          [8] Unavailable
          [1] Unavailable
          [2] Unavailable
          [3] 9450 RPM
          [4] 8620 RPM
          [5] 9000 RPM
          [6] 8100 RPM
          [7] Unavailable
          [8] Unavailable
          [3] Unavailable
          [4] Unavailable
          [6] 33 C (91 F)  Normal temperature range
          [9] Unavailable
          [10] Unavailable
        Shelf mapping (shelf-assigned addresses) for channel 6b:
DavidAtIBM
Looking more closely, I think I figured this out. We have the stack cabled upside down (at least according to the SAS cabling guide). So when we added shelf 8, it was to the top of the stack and not the bottom like we thought. Let me know if you find anything else.
aborzenkov
I stay corrected, your shelves are cabled fine. So it appears to be cosmetic display problem. It could be result of adding new shelf from "wrong" side. I am fairly confident that after reboot it will be shown in the right order.
P.S. usual practice is to alllocate consequitive shelf numbers in a stack, like 10, 11, 12, ... for a first stack, 20, 21, 22, ... for a second stack etc. It makes it easier to find the right shelf and follow cables when on site. It would also make it obvious which shelf is on "top" in your case :).
