ONTAP Discussions
Is there a way to disable showing nested junction points in a volume's snapshot?
ZhengCai
Right now I have two volumes, 'vol_test' and 'vol_nested'. 'vol_test' is mounted at /vol_test, and 'vol_nested' is mounted at /vol_test/vol_nested.
If I create a snapshot for 'vol_test', say 'snap-1', then the directory /vol_test/.snapshot/snap-1/vol_nested also shows up.
However, accessing it will throw the following error:
ls: reading directory .: Input/output error
It is very reasonable to not allow traversing nested junction point within a snapshot. But I wonder in this case why it is still shown there? Is there any way to configure the vserver/volume so that such junction points won't show up in the parent volume's snapshot?
Thanks in advance.
1 REPLY 1
robinpeter
If you store data under both volume.  i dont know any better way to do it.
This should be the outcome of some poor planning of directory structure.
but if you dont really store any date in "vol_test" it is there only for mounting the "vol_nested" under that, and create the path in that way.
Then, you can create virtual directory in your namespace called "/vol_test" and mount the "vol_nested" under that.
So you wont have this snapshot problem.
To achive this, you have to tap in to debug mode and system shell to create that directory or mount point.
