ONTAP Discussions
NFS Volume Mount Client Listing
chris_mckean
Hi Guys,
probably a few times a week I get asked "what servers mount that volume" as the mount points on our linux servers are often named differently from the volumes themselves.  for example
corporate-websites-htmlt:/vol/CORPWEBSERVICES_HTML
                      41943040   2183648  39759392   6% /lamp_website_home
So everybody but myself and the other guys who deal with the storage know this volume as '/lamp_website_home' and when I raise an incident around the volume filling up they do not know what I'm talking about.  This is where the difficulty comes in.  I have no way of saying "check server 1234 as i know that currently has the volume mounted" to point them in the direction of a server currently mounting this volume.
So the only way for them to know what volume I'm raising an incident about is by logging onto a lot of servers to see what the volume is known as in their world.  Then they can find out who owns the data in there and chat to them about clearing some out.
So I'm wondering if anyone knows any command or other way to get a lits of what IP's are currently mounting a volume via NFS?
We're currently running OnTAP 8.1.3(CMODE) and 8.2(CMODE) on our clusters.
Cheers
Chris
15 REPLIES 15
parisi
In clustered Data ONTAP, there is a way to see what clients are mounted via NFS, CIFS, etc.
::*> network connections active show -service ?
  mount                       Mount stream protocol
  nfs                         NFS stream protocol
  nfs-v2                      NFS version 2 stream protocol
  nfs-v3                      NFS version 3 stream protocol
  nlm-v4                      Network lock manager stream protocol
  sm                          Session Manager stream protocol
  ftp-ctrl                    FTP control stream protocol
  ftp-data                    FTP data stream protocol
  http-1-0                    HTTP version 1 stream protocol
  http-1-1                    HTTP version 1.1 stream protocol
  iscsi                       ISCSI stream protocol
  cifs-srv                    CIFS server stream protocol
  cifs-nam                    CIFS name server stream protocol
  loopback                    loopback stream protocol
  rf                          RC stream protocol
  rawscp                      Raw secure copy stream protocol
  discard                     Descard stream protocol
  port-map                    Port map stream protocol
  pass-thru                   Passthru stream protocol
  rclopcp                     Rc connection stream protocol
  nfs-v4                      NFS version 4 stream protocol
  fcache                      Flex cache stream protocol
  ctlopcp                     Ct connection stream protocol
  rquota                      Rquota stream protocol
  cifs-msrpc                  CIFS MsRpc stream protocol
  unknown                     unknown protocol
Example:
::*> network connections active show -service nfs*
              Vserver   Interface         Remote
      CID Ctx Name      Name:Local Port   Host:Port            Protocol/Service
Node: parisi-cdot-02
3461168229  4 flexvol   data2:2049        centos64.domain.win2k8.netapp.com:745
                                                               TCP/nfs
However, the above does not show you which volume is mounted. But it does help narrow it down...
To see specific information about volumes, turn on per-client stats for NFS:
::> statistics settings modify -display-rates true -client-stats enabled
Warning: System performance may be significantly impacted. Are you sure?
Do you want to continue? {y|n}: y
::> statistics show -object client
Object: client
Instance: 10.228.225.140
Start-time: 6/4/2014 14:47:08
End-time: 6/4/2014 14:47:22
    Counter                                                     Value
    hostname
    total-ops                                                      79
    nfs3-ops                                                        0
    nfs4-ops                                                        0
    cifs-ops                                                       79
    recv-data                                                      0B
    sent-data                                                     23B
    recv-packets                                                 3916
    sent-packets                                                    0
    volumes                             flexvol:unix
flexvol:rootvol
    avg-latency                                                   0us
    nlm-ops                                                         0
    mount-ops                                                       0
    local-ops                                                       0
    remote-ops                                                     24
    avg-latency-local                                             0us
    avg-latency-remote                                            0us
danmalcor
Did the connection between the client and the volume disapear in 8.3?
okieunixsam1
I agree I do not see hostname or volume listed in the stats output at all.
DOUGLASSIGGINS
Greetings,
Like Dan I also do not see a way to do nfsstats by client in 8.3, coming back to cmode (Justin probably remembers me from GX) I'd assumed this part was done. Is there another option I should be looking for in ngsh (or whatever this new cmode shell is called now)?
I can however still run nperf and pcpconfig, and I dont think I have to convert hex anymore.
DPOLEARY1
I too am desparate for a simple way of listing out what clients are connecting to what volumes. In 7-mode, you could look in /etc/rmtab to get a list, and although it wasn't 100% accurate (it often listed clietns after they disconnect), it was a huge help. I wouldn't think this should be that difficult to implement. On any linux box running an NFS server, I can run a "showmount -a" to get a list of clients and what nfs exports each is mounting. Migrations are very difficult when I have to take educated guesses on which clients will be affected. If anyone else has any methods of obtaining this information, please share. I'll keep searching and also post anything I find.
parisi
There is currently no way to do this today. I've been leaning on engineering to include this in a future version of ONTAP.
Jim_Robertson
I'm guessing this also means there is no way to tell if an NFS connection is encrypted or not?
For SMB (using OnTap 9.1), I use this command to get a lot of useful information about all the connections to my cluster:
cifs session show -fields node,vserver,lif-address,address,windows-user,auth-mechanism,shares,protocol-version,is-session-signed,smb-encryption-status
This is the closest I've been able to come to it for NFS. It shows me the servers and the LIFs they are connecting to, but I see no way to correlate this to a particular volume.
network connections active show -node * -service NFS* -fields node,cid,vserver,lif-name,local-address,local-port,remote-ip,remote-host,remote-port
Nate_Hudson
Is there any update to this thread?  I've tried this process on a system running 9.1P2, and there is still no correlation between volume and hostname.
yuvaraja
nfs modify -vserver vserver_name -showmount enabled
showmount -e (filerIP)
/test1 (everyone)
/test1/qtree1 (everyone)
/test1/qtree2 (everyone)
showmount -a vserverIP ...check with this command once..
DPOLEARY1
Thanks , but this does not provide a list of clients that are accessing a particular share.This just shows what exports are available. I need to be able to generate a list of clients that are currently mounting some export path (ex. /export), similar to what you would get by running "showmount -a" on a linux machine with an nfs server running.
Henrik_Aicher
Hi,
if you have a 1:1 relationship between Export and Lif,
why not use:
net connections active show -lif-name <name> -inst
Cheers,
Henrik
danmalcor
@Henrik_Aicher wrote:
Hi,
why not use:
Cheers,
Henrik
Of course having 500 LIFs has it’s own problems.
DPOLEARY1
Hi,
Thanks, but no we don't have a 1:1 relationship between exports and LIFs. I doubt that's a common configuration. On a typical system we may have 50 or so exports and mabye 5 LIFs.
There's still no great solution apparently. I usually have to run:
which returns a list of clients. Then if I'm looking for a specific export, I run a script which goes out to every client in that list and check if it's mounting that export. It's a lot of work to gather information that should be available with a simple command imo.
Vidhs
Just learnt that the ability to map NFS clients to specific volume and IP addresses are being introduced from ontap 9.7, something like this. As ontap 9.7 is just released, will be interesting to look into this availability :
cluster::> nfs connected-clients show ?
  [ -instance | -fields <fieldname>, ... ]
  [[-node] <nodename>]                                               Node Name
  [[-vserver] <vserver>]                                             Vserver
  [[-data-lif-ip] <IP Address>]                                      Data LIF IP Address
  [[-client-ip] <IP Address>]                                        Client IP Address
  [[-volume] <volume name>]                                          Volume Accessed
  [[-protocol] <Client Access Protocol>]                             Protocol Version
  [ -idle-time <[<integer>d][<integer>h][<integer>m][<integer>s]> ]  Idle Time (Sec)
  [ -local-reqs <integer> ]                                          Number of Local Reqs
  [ -remote-reqs <integer> ]                                         Number of Remote Reqs
Jim_Robertson
Thanks, @Vidhs !
Here's a brief overview they did as part of the Tech OnTap podcast:
https://whyistheinternetbroken.wordpress.com/2019/11/08/ontap97-feature-sneak-peek-nfs-client-to-volume-mapping/
I, for one, am very glad to see that this has been added.
