ONTAP Discussions
ONTAP 9 downgrade to 8.2.X 7-mode in fresh installation
paulchan
Hi All,
Anyone know how to downgrade from ONTAP 9 to 8.2.X 7-mode in fresh installation?
Thanks!!
Regards,
Paul
2 REPLIES 2
ESPENNILSEN
Hi Paul,
Check out KB000027886 article. (Couldn't find the KB for ONTAP 9)
But I recommend contacting NetApp support. You might also need to convert your licenses.
Regards,
Espen
chenguanghui
hello:
    Downgrade can only be a version of a version of the downgrade, in addition to the cluster mode can not be directly downgraded to 7-mode, need to modify the parameters, the following article may help you
https://kb.netapp.com/Legacy/ONTAP/7Mode/How_to_convert_a_clustered_Data_ONTAP_8.x_node_to_a_7-Mode_node
Best Regards,
