ONTAP Discussions
Open System SnapVault not starting
FABRICIO_ALMEIDA
Hello folks,
I want to backup data using OSSV, i already installed the client in my Linux machine, but when i try to start the copy, the console output the following error:
2220> snapvault start -S 192.168.169.7:/etc 2220:/vol/cronos/etc
Invalid path: /vol/cronos/etc
usage:
This command is available only on a snapvault secondary.
snapvault start [-r [-f]] [-w] [-k <kbs>] [-t <n>] [-p <conn_mode>] [-o <options>] [-S [<primary_system>:]<primary_path>] [<secondary_filer>:]<secondary_path>
where <options> is <opt_name>=<opt_value>[[,<opt_name>=<opt_value>]...]
For more information about the available options, please see the
SnapVault man page.
Consider:
/vol/cronos(volume)/etc(qtree)
Observation: 2220 is a ficticious name.
Thanks in advice!
1 ACCEPTED SOLUTION
FABRICIO_ALMEIDA
I already resolve this problem.
The NetApp dont allow a qtree named "/etc" because this is a system folder of NetApp.
After changed to:
2220> snapvault start -S 192.168.169.7:/etc 2220:/vol/cronos/etc_cronos
Works like a charm.
1 REPLY 1
FABRICIO_ALMEIDA
After changed to:
Works like a charm.
