ONTAP Discussions
Problem mounting NFS qtree from RH 6.x
stetedeschi
Hi All,
I'm really confused about what's happening.
On any RH 6.x I'm not able to mount with any NFS version any qtree exported in my volume. Same exported qtrees work fine with either RH 5.x and RH 7.x, no matter if I choose version 3 or 4.
Error is always access denied.
Same 6.x servers works fine in 7-Mode environment
Path to the qtree is correcty enabled at read level for all the servers.
Any idea?
Many Thanks
Stefano
1 REPLY 1
SeanHatfield
check the export policy on the svm root vol, and the qtree parent vol.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
