ONTAP Discussions
Routing problems with Intercluster LIF
sraudonis
Hello,
in a small environment i have a 2 node system and a single node system in a remote office connected via vpn. I make daily snapmirror updates through that vpn.
I have now a problem:  How to make a every time working Intercluster configuration.
When the intercluster is in the same IP subnet as the management interfaces, i got problems, that sometimes services (like Autosupport) can use the intercluster IP as source and not the node management LIF. (Documented in the network management guide)
So i configured a own management network, with ONTAP 9.1 all was fine, but after a upgrade to 9.2 i can't reach the SSH and HTTP services on the management interfaces from clients in the same subnet as the Intercluster LIF.
Subnet A - NetApp Management interfaces
Subnet B - Intercluster and also some Clients
With enabled Intercluster in Subnet B i can ping the Management interfaces in Subnet A from Subnet B from a client, but can't use SSH or HTTP. When i disable the Intercluster i can connect via SSH or HTTP.
As a workaround i made now 3 subnets, a own subnet for Intercluster.
But can that be correct, that the management isn't useable when a Intercluster is present in the source network?
Kind regards
Stefan
1 ACCEPTED SOLUTION
sraudonis
The source of the problem is the removal of IP fastpath in 9.2:
https://kb.netapp.com/app/answers/answer_view/a_id/1072895
2 REPLIES 2
danthro
I'm having the same issue.  You ever find a fix for this?
sraudonis
