ONTAP Discussions
Snapmirror SVM and Snapmirror Volume
VKS
Hi Guys,
Just want to know, how to differentiate or to find out whether the Snapmirror is configured on SVM or on Volume or on both.
regards
VK
6 REPLIES 6
colsen
Hello,
In cDOT 8.3.x, Snapmirror relationships are established within the SVM itself.  Going between 8.1.x, 8.2.x and 8.3.x it seems like there are some "cosmetic" differences between how snapmirrors are established and managed, but the SVM still owns the protection policy.  This is the link to the 8.3 Snapmirror best practices guide:
http://www.netapp.com/us/media/tr-4015.pdf
If you're running a previous version just make sure you grab the document for your particular cDOT in that some of the commands and/or SystemManager screens will look different.
Good luck,
Chris
JGPSHNTAP
in 8.3.1 if you are creating an SVM-DR relationship, the relationship will look like
SVM_NAME:
1VINAYKUMAR
Hi Guys,
Thanks for the reply, when i run the Snapmirror show command on cluster. it shows the below output and its a bit difficult to understand or if the snapmirror configuration is on SVM or volumes.
SourceLocation DestinationLocation Status MirrorState LagTime RelationshipType
PEPNS00044-PI: PEPNS00044-DR: idle snapmirrored 00:04:47 data_protection
PEPNS00044-PI:vl_VMdata PEPNS00044-DR:vc_VMdata idle snapmirrored 00:04:45 data_protection
PEPNS00044-PI:vl_home PEPNS00044-DR:vc_home idle snapmirrored 00:04:45 data_protection
PEPNS00044-PI:vl_rdshome PEPNS00044-DR:vc_rdshome idle snapmirrored 00:04:45 data_protection
PEPNS00044-PI:vl_rdsprofiles PEPNS00044-DR:vc_rdsprofiles idle snapmirrored 00:04:45 data_protection
the above output shows the SVM as well as the SVM:Volname, whereas as for as i understand it should be only SVM: but not with the volumes, if configured for SVM DR.  a bit confusing for me to understand the Snapmirror configuration.
regards
VK
JGPSHNTAP
The first entry shows the SVM - SVM-DR relationship and then underneath are all the vols attached to it
1VINAYKUMAR
OK, so it means if we configure the Snapmirror DR configuration, The Snapmirror Show command will show the status of Snapmirror SVM DR along with volumes associated on the concerned SVM.
dbenadib
Nop
Actually vserver snapmirror and volume snapmirror is slightly different :
The first line means that you have a svmdr relationship. This relationship is holding all the relationship for the prod vserver.
You can verify it by using this command:
Snapmirror show -destination-path svm-dr: -expand
This command will give you all the detailled relationship under the svmdr replication
Also vserver snapmirror is using the vserver property "subtype" so can you send us the ouput of vserver show -field vserver,subtype
The dr destination vserver (on the DR cluster) should be reported as a dp-destination subtype.
Regards
