ONTAP Discussions
Strange NFS mount issue
James_Castro
I have a strange situation here at the customer site that I have never seen before and I am hoping someone can point me in the right direction.
I have a server that is able to mount a volume via NFSv3 from a vserver.  When I try to mount another volume from the same vserver via NFSv3 I get this message:
[root@fgtd-333333-aspadavecchia-db001 mnt]# mount -t nfs -v -o rw,nointr,noacl,noatime,rsize=32768,wsize=32768,defaults,vers=3,tcp,mountproto=udp,bg,hard,nolock vsnfsbbl.bbcs1.trcl1va2.mhint:/bbl_nfs_td1_333333_aspadavecchia_dbo/db001 /home/oracle
mount.nfs: trying text-based options 'nointr,noacl,rsize=32768,wsize=32768,vers=3,tcp,mountproto=udp,bg,hard,nolock,addr=10.8.236.4'
mount.nfs: prog 100003, trying vers=3, prot=6
mount.nfs: trying 10.8.236.4 prog 100003 vers 3 prot TCP port 2049
mount.nfs: prog 100005, trying vers=3, prot=17
mount.nfs: trying 10.8.236.4 prog 100005 vers 3 prot UDP port 635
mount.nfs: mount(2): No such file or directory
mount.nfs: mounting vsnfsbbl.bbcs1.trcl1va2.mhint:/bbl_nfs_td1_333333_aspadavecchia_dbo/db001 failed, reason given by server: No such file or directory
If I mount using no options, the mount is successful but only with NFSv4
[root@fgtd-333333-aspadavecchia-db001 mnt]# mount -v vsnfsbbl.bbcs1.trcl1va2.mhint:/bbl_nfs_td1_333333_aspadavecchia_dbo/db001 /home/oracle
mount: no type was given - I'll assume nfs because of the colon
mount.nfs: timeout set for Wed Jul 27 21:04:10 2016
mount.nfs: trying text-based options 'vers=4,addr=10.8.236.5,clientaddr=10.8.224.122'
vsnfsbbl.bbcs1.trcl1va2.mhint:/bbl_nfs_td1_333333_aspadavecchia_dbo/db001 on /home/oracle type nfs (rw)
Here is the volume that we can mount via NFSv3:
[root@fgtd-333333-aspadavecchia-db001 mnt]# mount -t nfs -v -o vers=3 vsnfsbbl.bbcs1.trcl1va2.mhint:/asp/asp /mnt/asp
mount.nfs: timeout set for Wed Jul 27 21:09:59 2016
mount.nfs: trying text-based options 'vers=3,addr=10.8.236.7'
mount.nfs: trying 10.8.236.7 prog 100003 vers 3 prot TCP port 2049
mount.nfs: trying 10.8.236.7 prog 100005 vers 3 prot UDP port 635
vsnfsbbl.bbcs1.trcl1va2.mhint:/asp/asp on /mnt/asp type nfs (rw,vers=3)
I even tried using the same export policy that the /asp volume uses.
1 ACCEPTED SOLUTION
James_Castro
UPDATE:  I have found the issue and fix for this problem.
Turns out that the LS mirror of the vserver root volume was causing the issue.  The root volume LS mirror had not been updated in quite a long time.  This causes an issue when trying to mount new volumes.  Once I updated the mirror the issue was gone.
https://kb.netapp.com/support/index?page=content&id=3013933
Make sure you LS mirrors are updated regularly.
James
1 REPLY 1
James_Castro
James
