ONTAP Discussions
Users home directories and quotas
RANJBASSI
Hi All
Hoping if someone can assist with an issue I am having with migrating home shares to a CIFS share on our NetApp FAS8020 running Ontap 8.2.1 7 mode.
I have tested migrating home shares using Robocopy to ensure permissions are retained and the good news is this part works ok. I have enforced user quotas on the qtree I have created for Home directories however once the data moves over and I map the CIFS share to a client it doesnt seem to pick up the quota for the existing files already in the share, it does however add to the quota if I add any new files into it.
So I created a 100mb quota and migrated one of home directories over which was fine but the quota in Windows showed 100mb free of 100mb. Once I filled it up with 5 X 20mb files it then activated the quota and it was full.
Is it by design that the quota wont work for exisitng files migrated over? I am assuming this is because of the way the ownership of the way the robocopy job is run?
ANy advice on this would be most appreciated.
Thanks
1 ACCEPTED SOLUTION
f_defrocourt
Hi RANJBASSI,
You have pointed the right solution. In robocopy job, there is a parameters who keep the owner of the files transfert by the robocopy job.
So you have to redo your robocopy job with the "/COPYALL" parameter.
Hope i was help.
François
2 REPLIES 2
f_defrocourt
Hi RANJBASSI,
Hope i was help.
François
RANJBASSI
Thank you, that was the answer. It was a switch that needed to be used to copy Ownership details.
