ONTAP Discussions
What is the likely problem if the volume can't be seen by users?
newbeee
As per topic
7 REPLIES 7
Renifa
Hi,
To understand your question better can you tell me if its CIFS shares or NFS?
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
newbeee
I'm new, what's is the different between cifs share and nfs?
Is"t the different protocol use?
Renifa
Hi,
Yes its different protocols. CIFS used for windows and NFS for unix/linux. To make it simple are you trying to access the volume from Windows machine or linux/Unix machine?
newbeee
Window machine
shatfield
Users don't see volumes, they see shares and/or exports.
Check that the volume is online, the type is RW, the security style is correct (likely NTFS for a windows share), the junction path is not "-", and the junction path is active:
 show -vserver * -volume * -fields junction-path,state,security-style,type,junction-active
Check that cifs is up on the SVM (vserver) that owns the volume:
vserver cifs show
Check that the volume's junction path is shared, the share is browsable, and the ACL includes the user or a group to which they belong
vserver cifs share show
Check that the date and timezone are correct on the cluster
date
Check that the LIF the user is connecting to is up, and that the port it is currently homed on is correct
net int show -role data -fields curr-port,curr-node,address,netmask,status-oper
Verify that the time and date on the cluster and the domain controller(s) are all wihtin 5 minutes of each other
Verify that a DNS entry was created for the SVM's server name (as shown in the output of "vserver cifs show")
Verify the user can ping the SVM by ip and by name
newbeee
If it is not in vcenter ..
How do we check.
Not a cluster mode
NAYABSK
May i know is the error you are getting when you trying to access the CIFS share from windows machine ?
Did you check the following ?
  1. Name Resolution
  2. Authentication
  3. Permissions
Did the cifs worked before ? Or is this a new issue ?
Did you try to ping the storage controller from the windos server and vice versa ?
To check the authentication Can you go to Start-->Run--> \\<Storage_Controller_Name>
Also check the permission Start > Run > \\<Storage_System_Name>\Share
Also remember the storage controller time and your windows machine time difference shouldn't be  more than 5mins
So use command DATE in Storage to check the controller time and also check the time in your windows and correct if there is any lapse.
Let us know trying out above
