ONTAP Discussions
system health node-connectivity
IanThompson
Hello
There used to be some greate commands in 8.X
for example:
system health node-connectivity shelf show  -node * -num-paths ❤️
Any idea where a simialr command is in ontap 9.X
Thanks
Ian
3 REPLIES 3
GidonMarcus
the same command you asked about works for me on 9.1P6 under "set diag" priv.
G
Gidi Marcus (Linkedin) - Storage and Microsoft technologies consultant - Hydro IT LTD - UK
IanThompson
Strange, does not appear on my version…
XXXX::*> version
NetApp Release 9.1P6: Tue Jun 20 21:52:46 UTC 2017
TC2-SPSE-CLS01::*>
XXXXX::system*> set -privilege diagnostic
Warning: These diagnostic commands are for use by NetApp personnel only.
Do you want to continue? {y|n}: y
XXXXX::system*>
    capability        chassis           cluster-switch    configuration
    controller        feature-usage     fru-check         ha
    health            license           node              ontapi
    script            service-processor services          smtape
    snmp              timeout
XXXXXX::system*> health
    alert       autosupport config      policy      status      subsystem
XXXX::system*>
deadsenator
Not sure if you've already discovered this or not, but the command still works even if it does not show as an available command. Even at the diag priv level.
netapp::*> system health
netapp::*> system health node-connectivity
command is complete
Tabbing out says command is complete. It is not complete! If you start typing the correct word it will tab-complete for that word only. I do not like this.
netapp::*> system health node-connectivity shelf show
                                                       Num    Num
Node               Shelf Name                          Disks  Paths Status
netapp-01       2.17                                  24     2   ok
netapp-01       2.16                                  24     2   ok
Useful shelf commands:
system health system-connectivity shelf show
system health node-connectivity adapter show
I would like to discover how to reveal these commands on my systems again as we progress through newer versions.
