ONTAP Hardware
Could I use a Empty formely SAS Disk DS4243 Shelf for SSD?
rojas
Hi All, Quick Question
We got a new hafl populated SAS Disk Shelf DS4243, then We passed the 12 disks to other Disk shelves
Now the customer want 9 units of 100GB SSDs
Can I use this empty shelf?
Thanks,
Mauricio
2 REPLIES 2
chriszurich
If the shelf is completely empty (SSD shelves must be isolated) you should be able to use it as a new SSD shelf.  Keep in mind that you'll want to add it as a new stack on a controller which only serves out SAS & SSD disk.  This will ensure that CP commits are not hindered by slower disk on the back end.  The outstanding question would be whether NetApp sells just the disk.
rojas
yes, NetApp does it, I just quoted ten inviduals SSDs for this shelf. thanks
