ONTAP Hardware
Create Aggregate with 23 disks and one hot spare?
NEWNETAPP987
Hi,
I added two new, 24 disk shelves, to my 6220.
I plan to add 1 shelf to each controller.
I think I will create a 23 disk aggregate -- (21+2) and one hot spare.  I will have one raid group size 11 and one size 10.
Does this seem like a reasonable implementation or is there a better one?
Thanks,
4 REPLIES 4
rwelshman
What type of disks will they be? SAS / SATA, etc.
If you have two raid gropus, there will be four parity disks. If you want a true 21 + 2, then you should set the raid group size to be 23 disks total, and have one raid group. But that would be a large raid group for large sized disks - since the rebuild time will be so long.
aborzenkov
Max SATA raid group size is 20 disks, so 23 may not be possible.
georgevj
True.
Just FYI;
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Cannot find the answer you need? No need to open a support case - just CHAT and we’ll handle it for you.
JGPSHNTAP
I assume he said SAS, b/c he was saying 23..
If we are talking SAS, I would do RG 22  WHy would you do rg11 and 10. that makes no sense..
